Gerardo Mendoza
Bengal o copan cp2500
that I would come better bengal plotter or copan2500
  1. 1. that I would come better bengal plotter or copan2500
    • copan cp 2500 o bengal
      0
    • help
      0
Good friends wanted to help me with further questions last time you see vinyl cutting plotter was best for curves if a Bengali or a laser point perodecidi wait and then now I have to buy the copam cp2500 but want to know if this helps me to plotter cutting curves or stay with the bengal thousand thanks.
There are spanish reading/speaking members here . I suggest typing in your native language as the english post is not easy to understand . The members will translate better so we can understand :D .
the Copam cuts curves great as does most all cutters . Copams are a step or 2 up from the basic cutters . I have no knowledge about Bengali cutters .
I don't understand the " cutting corners " part ;D  In English , cutting corners can mean to save money by buying cheaper machines or doing things in a way not to spend as much . If literally meanimg cuttng a corner in vinyl .. I don't have a clue what a Bengali is or what it does ... but any cutter will cut corners . If you are meaning contour cutting around a printed decal , the copams are not set up to do that to my knowledge .
Thanks for the translation Proto  ;D
la duda mia es que un amigo me comento que hay plotters que solo cortan linealmente y no pueden cortar curvas y lo que busco es un plotters para poder cortar curvas ,ya sea como tribales para vehiculo ,por eso preguntaba cual me aconsejan un copam cp 2500 o un bengal servo
translation
doubt is that a friend of mine told me that there are only linear cutting plotters and can not cut corners and what I seek is a plotter to cut corners, either as tribal vehicle, which wondered why I recommend a cp COPAM 2500 or servo bengal
translation
thanks guys for your answers, I think I'll stick with the cp COPAM 2.5 million thanks to everyone who helped me
  El Copam tiene un motor paso a paso mientras que el otro tiene un motor servo. El servo motor es un no m
ohh no sabia eso que el copam es mucho mas preciso que el bengal y la verdad me inclino mas por uscutter por la forma en que majenan sus productos ,lo unico malo es que las operadoras de las lineas telefonicas no contestan llevo 2 dias uqeriendo saber cual es el peso total del copam para sacar los calculos del envio a centro america y por otra parte alguien sabe donde puedo encontar un manual del copam cp 2500 para leer sobre el y saber mas para poder acortar mi ignorancia en esto ,gracias
eres bienvenido
You are welcome
