Gerardo Mendoza 0 Posted February 16, 2011 Good friends wanted to help me with further questions last time you see vinyl cutting plotter was best for curves if a Bengali or a laser point perodecidi wait and then now I have to buy the copam cp2500 but want to know if this helps me to plotter cutting curves or stay with the bengal thousand thanks. Share this post Link to post Share on other sites
Rodger 527 Posted February 17, 2011 There are spanish reading/speaking members here . I suggest typing in your native language as the english post is not easy to understand . The members will translate better so we can understand . the Copam cuts curves great as does most all cutters . Copams are a step or 2 up from the basic cutters . I have no knowledge about Bengali cutters . Share this post Link to post Share on other sites
Gerardo Mendoza 0 Posted February 17, 2011 la pregunta es que me vendria mejor para trabajar un copan o un bengal ,para cortar en curvas gracias Share this post Link to post Share on other sites
prototype66 20 Posted February 17, 2011 the question is that I'd be better to work a bengal monopolize or to cut corners by ? Share this post Link to post Share on other sites
Rodger 527 Posted February 17, 2011 I don't understand the " cutting corners " part In English , cutting corners can mean to save money by buying cheaper machines or doing things in a way not to spend as much . If literally meanimg cuttng a corner in vinyl .. I don't have a clue what a Bengali is or what it does ... but any cutter will cut corners . If you are meaning contour cutting around a printed decal , the copams are not set up to do that to my knowledge . Thanks for the translation Proto Share this post Link to post Share on other sites
Conquestgraphics 4 Posted February 18, 2011 the question is which is better for cutting curves bengal or laserpoint Share this post Link to post Share on other sites
Gerardo Mendoza 0 Posted February 18, 2011 la duda mia es que un amigo me comento que hay plotters que solo cortan linealmente y no pueden cortar curvas y lo que busco es un plotters para poder cortar curvas ,ya sea como tribales para vehiculo ,por eso preguntaba cual me aconsejan un copam cp 2500 o un bengal servo Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 18, 2011 translation doubt is that a friend of mine told me that there are only linear cutting plotters and can not cut corners and what I seek is a plotter to cut corners, either as tribal vehicle, which wondered why I recommend a cp COPAM 2500 or servo bengal Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 18, 2011 cualquiera de los cortadores de vinilo cortar las esquinas, curvas, l Share this post Link to post Share on other sites
Gerardo Mendoza 0 Posted February 18, 2011 gracias amigos por sus respuestas ,creo que me quedo con el copam cp 2500 mil gracias a todos los que me ayudaron Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 18, 2011 translation thanks guys for your answers, I think I'll stick with the cp COPAM 2.5 million thanks to everyone who helped me Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 18, 2011 su bienvenida Your welcome Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 18, 2011 My Spanish class = D- in 8th grade . . . Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 18, 2011 LOL ME 2 but this seems to work pretty good!! http://www.studyspanish.com/translator.htm Share this post Link to post Share on other sites
Rodger 527 Posted February 18, 2011 El Copam tiene un motor paso a paso mientras que el otro tiene un motor servo. El servo motor es un no m Share this post Link to post Share on other sites
Gerardo Mendoza 0 Posted February 19, 2011 ohh no sabia eso que el copam es mucho mas preciso que el bengal y la verdad me inclino mas por uscutter por la forma en que majenan sus productos ,lo unico malo es que las operadoras de las lineas telefonicas no contestan llevo 2 dias uqeriendo saber cual es el peso total del copam para sacar los calculos del envio a centro america y por otra parte alguien sabe donde puedo encontar un manual del copam cp 2500 para leer sobre el y saber mas para poder acortar mi ignorancia en esto ,gracias Share this post Link to post Share on other sites
Rodger 527 Posted February 19, 2011 eres bienvenido You are welcome Share this post Link to post Share on other sites
crgraphics 0 Posted February 19, 2011 The bengal cutter is a GCC with servo motors sold by signwarehouse i think. Good cutter also just a little old. Share this post Link to post Share on other sites
Gerardo Mendoza 0 Posted February 19, 2011 gracias por el manual les agradesco a todos Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 19, 2011 Su satisfacci Share this post Link to post Share on other sites
