PAUPAU 0 Posted January 12, 2011 I am trying to do a cut in sign blazer and just can't get this to work. I have been able to make cuts in another software, but it doesn't have the weeding feature. I have gone through the step and refered back to the manual, but I am missing something, no response to "cut" command. I'm using the MH 871. Thanks Share this post Link to post Share on other sites
Rodger 527 Posted January 12, 2011 With no other info than what you have given , I would guess you don't have the ports assigned correctly . Read up about setting the port # in your device manager on your computer & then the same in SignBlazer . Share this post Link to post Share on other sites
PAUPAU 0 Posted January 12, 2011 Thanks I'll try that. When I first setup the machince I was able to do cuts and just did cuts in a different software, maybe it cause the port configuration to change. Share this post Link to post Share on other sites
PAUPAU 0 Posted January 12, 2011 Well I didn't reset anything, it just worked on the 10th or so restart of the program. Thanks for the quick response. Share this post Link to post Share on other sites
deth502 39 Posted January 12, 2011 id still check the ports. i know mine likes to randomly change them for me some times. it seems that if i start sb without the cutter plugged in and then plug it in after sb is running is when it will do it. if i plug the cutter in, then open sb, i never have a problem. Share this post Link to post Share on other sites
Dr12volt1338 116 Posted January 21, 2011 I also found I had to plug the cutter into the same USB port each time... That may be general knowledge but I didn't know it so maybe it will help someone else Share this post Link to post Share on other sites
