cribbert 0 Posted December 11, 2010 I am looking for some help cutting snow capped letters I'm not sure how to explain this but i will try thanks for any help I would like to cut the solid letter and then cut the Snowcap seperatley and then overlay the cap on the letter Iam using corel draw and cutting master 2 thanks again Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 11, 2010 http://www.dafont.com/almonte-snow.font http://www.dafont.com/snowtop-caps.font http://www.dafont.com/plymouth-rock-snowd.font Share this post Link to post Share on other sites
prototype66 20 Posted December 11, 2010 http://simplythebest.net/fonts/fonts/snow_caps.html Google is my best friend! Share this post Link to post Share on other sites
roxanneupnorth 106 Posted December 11, 2010 Can not help with Corel but can explain it in Illustrator.....Might need a diagram which I will try to post later.... - Set your text and colour it black.... - Convert to outlines..... - Using Group Selection Tool select all white pieces (inside and outside paths) and cut.... - Then select all black pieces and lock..... - Then paste white pieces in front.... - On some letters there will be little bits....These need to be subtracted (Pathfinder tool) from the larger piece of snow..... - Select all snow and add them together (Pathfinder tool).... - Unlock black..... - You should now have black on lower level and white on upper level and both can be cut separately... Share this post Link to post Share on other sites
cribbert 0 Posted December 12, 2010 Thanks for the help everyone Share this post Link to post Share on other sites
