buddy 7 Posted October 24, 2010 Here is a van I wrapped...forgot to take a picture of the back with Perf. will do that later. Used white Oracal Cast that worked like a charm! The back was my challenge as I have never worked with Perforated material before.... Dazzel Share this post Link to post Share on other sites
bayotle 26 Posted October 25, 2010 Not to bad ... guess you need to consider what you had to work with and beings it was a dodge, it turned out pretty good! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 25, 2010 Not to bad ... guess you need to consider what you had to work with and beings it was a dodge, it turned out pretty good! Careful the MOPAR posse is lurking! LOL Share this post Link to post Share on other sites
bayotle 26 Posted October 25, 2010 Careful the MOPAR posse is lurking! LOL I was wondering how long it'd be before you slammed me for one of my remarks! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 25, 2010 Careful the MOPAR posse is lurking! LOL I was wondering how long it'd be before you slammed me for one of my remarks! always with love though Share this post Link to post Share on other sites
bayotle 26 Posted October 25, 2010 Careful the MOPAR posse is lurking! LOL I was wondering how long it'd be before you slammed me for one of my remarks! always with love though You must be a heavy equipment operator cause you sure can shovel the shyt!!! Share this post Link to post Share on other sites
buddy 7 Posted October 27, 2010 HEY...were complimenting ME HERE folks...... not talking heavey equipment and shyt (whatever that means) lol :D Yes, seeing's how it was a DODGE it was a challenge as I am a CHEVY GIRL to the CORRRRRRRR! Share this post Link to post Share on other sites
bayotle 26 Posted October 27, 2010 HEY...were complimenting ME HERE folks...... not talking heavey equipment and shyt (whatever that means) lol :D :D Yes, seeing's how it was a DODGE it was a challenge as I am a CHEVY GIRL to the CORRRRRRRR! Hey, we took care of the compliments and a few other things, take a chill pill there missy! Share this post Link to post Share on other sites
buddy 7 Posted October 27, 2010 ok....chillin'....onward Share this post Link to post Share on other sites
tattoo.dan 0 Posted October 28, 2010 Looks good. Perf is surprisingly easy to work with. Pretty forgiving. I was nervous on my first install... Share this post Link to post Share on other sites
buddy 7 Posted October 29, 2010 Tattoo.dan - I was VERY nervous on my first install as well, must be why I screwed up 3 times and then the fourth time I went to Max at USCUTTER who is an EXPERT at it and he showed me how to do it...HE---made it look super easy! I think between it being really cold, using the wrong Laminate (too thick) and it being a Dodge with DEEP curvature on the bottom of the window...and well, NEVER DOING IT BEFORE I had the odds stacked against me. Max pulled me through though andf I think next time will be much easier! THe trick is to use that soft felt squeegee first and then the rubber one to stake it down! Dazzel Share this post Link to post Share on other sites
tattoo.dan 0 Posted October 29, 2010 I only use the felt squeegee. Never had any problems yet....I could see how using a harder squeegee could cause issues...I also use liquid laminate as well, so maybe that's why I have had better luck with the installl. How does the overlaminate you use work when it's raining? I've heard it makes it impairs the vision some... Share this post Link to post Share on other sites
neron15210 10 Posted October 29, 2010 If perforated film is laminated it really does not matter what squeegee you are using, it only maters how you use it.. So, I use middle hinge And install left side first. I would not suggest to use wet install for perforated film (laminated) because moisture stays trapped under it. Nice work on the lettering BTW :thumbsup: Share this post Link to post Share on other sites
buddy 7 Posted October 30, 2010 Neron, Max used this incrediable technique. He cut the backing down the middle (carefully) while still attached to the perf...this releases the tension and started as you say on the left side (why is that important?) He had no problems and no bubbles! INCREDIABLE I TELL YOU!!! And what do you mean....doesn't matter what squeegee you are using if laminated....did you read my post :-....THREE TIMES I SCREWED UP because of creases and folds and...and...and :thumbsup: All's I can say is practice makes perfect! Another factor....GREENSTAR LAMINATE....HORRIBLE!!!!!!!!!!! Stay away from it!!! Very thick and only works with FLAT SURFACES! There, my 2 cents! Share this post Link to post Share on other sites
neron15210 10 Posted October 30, 2010 What I meant was that practice is mother of perfection. Middle hinge is exactly what Max did, with only difference, I separate perf before cutting (less room for error) Lamex 2 mil laminate for perf works great for me (not as good as 3M but price....) Share this post Link to post Share on other sites
tattoo.dan 0 Posted November 1, 2010 What I meant was that practice is mother of perfection. Middle hinge is exactly what Max did, with only difference, I separate perf before cutting (less room for error) Lamex 2 mil laminate for perf works great for me (not as good as 3M but price....) same laminate and same method used here! Share this post Link to post Share on other sites
neron15210 10 Posted November 1, 2010 Just finished Chevy blazer , rear and 2 side windows . Using lamex laminate and solvex 50/50 for rear window and solvex 70/30 for side windows (customer signed waiver because 70/30 is not for vehicles) Talking about curve on the window....blazer is ....uf But install went smooth. - Dry install - middle hinge - blue 3M squeegee Share this post Link to post Share on other sites
bayotle 26 Posted November 1, 2010 Now that's how ya do it - On a Chevy! Share this post Link to post Share on other sites
buddy 7 Posted November 2, 2010 Neron that looks AMAZING...why may I ask would he request 70/30 and if not intended for vehicles then what? Boats? Did you do the design? I LOVE IT! Share this post Link to post Share on other sites
tattoo.dan 0 Posted November 2, 2010 Neron that looks AMAZING...why may I ask would he request 70/30 and if not intended for vehicles then what? Boats? Did you do the design? I LOVE IT! It's not intended for vehicles for safety purposes. It is intended for store windows and such as it has fewer holes and more printable area, which equals better looking image(i am sure that is why he wanted it) but less visibility. I use it on vehicles a lot, still pretty easy to see out, but neron is right to have them sign for liability purposes in case of an accident... Share this post Link to post Share on other sites
buddy 7 Posted November 2, 2010 Good to know Tattoo-Dan-the-Man See, I am learning sompin' new everyday Share this post Link to post Share on other sites
neron15210 10 Posted November 3, 2010 thanks for kind words about my work and thanks Dan for answering question. Here is another pic Share this post Link to post Share on other sites
