Benr98 40 Posted January 1, 2008 I have an image that I want to combine all layers than covert it to nodes, any help with this?? Thanks. Jenny Share this post Link to post Share on other sites
Jerry Bonham 1 Posted January 2, 2008 Hello Jenny, You do not say what software you are using. If it is SignBlazer simply select what you want to combine and press the letter C on your keyboard. Jerry from SignBlazer. Share this post Link to post Share on other sites
Benr98 40 Posted January 2, 2008 Hello, I do have Signblazer, but my question if for how to combine in Inkscape! Thanks. Jenny Share this post Link to post Share on other sites
dgreenh 9 Posted January 2, 2008 Not exactly sure what you are asking but To combine you select the objects then go to PATH > Combine To Weld them together you use PATH > Union To Trim you use PATH > Difference Sometimes you have to trim objects before you combine or weld them or weird things happen. Share this post Link to post Share on other sites
Benr98 40 Posted January 2, 2008 Thanks Green, I'll give it a try!! :thanks: Share this post Link to post Share on other sites
