leonard85 0 Posted December 22, 2007 When I turn my cutter on all it will do is make a clicking noise and the lights and the screen blink but wont turn anything on. Share this post Link to post Share on other sites
stickygrafix 2 Posted December 22, 2007 first of all, what cutter is it? Make sure you are plugged in good on both the machine and in the wall. are you using the cord that came with the cutter? Only reason I ask that is because one day I packed up my machine along with all my computer stuff and moved it all and when I went to plug it back in, I used the cord from my computer instead and it wouldn't keep the power on. it would just flicker Share this post Link to post Share on other sites
leonard85 0 Posted December 22, 2007 The cutter is the 50" MH1351. I was using it when it stopped working Share this post Link to post Share on other sites
stickygrafix 2 Posted December 22, 2007 does the 1351 have a fuse that might be blown? Share this post Link to post Share on other sites
leonard85 0 Posted December 22, 2007 I put a new one in Share this post Link to post Share on other sites
Popeye 0 Posted December 23, 2007 I'm not sure if that model has the two end safeties or not... make sure the carriage isn't against the safeties, extreme right or left. If it is, turn power OFF and manually move the carriage of the safety. Share this post Link to post Share on other sites
leonard85 0 Posted December 23, 2007 Still does the same thing Share this post Link to post Share on other sites
haumana 1,221 Posted December 23, 2007 So it does turn on? You get power to the plotter, but it's non-functional? Share this post Link to post Share on other sites
leonard85 0 Posted December 23, 2007 It gets power but everything blinks and nothing comes up on the screen and the fans dont turn on or anything. It makes a cliking noise and the blade will click up and down Share this post Link to post Share on other sites
haumana 1,221 Posted December 24, 2007 It gets power but everything blinks and nothing comes up on the screen and the fans dont turn on or anything. It makes a cliking noise and the blade will click up and down PM Ken, and you can also post this in the support request board. To me, it doesn't sound like a power/usb/computer issue - it sounds like it's all cutter. Share this post Link to post Share on other sites
leonard85 0 Posted December 24, 2007 The cutter only has maybe and hour of cutting time since new and its already having problems Share this post Link to post Share on other sites
kenimes 42 Posted December 25, 2007 Could be a manufacturers defect....they happen. Sounds like a motherboard issue to me, with the other possibility being a power supply. Shoot me a PM with your phone number and I will give you a ring. Share this post Link to post Share on other sites
