firemalt
Additional pinch roller
The PCut uses a fan and duct system to help hold the material flat while feeding, which means extra pinch rollers are not needed. We do have them though, if you would like: www.uscutterdirect.com
I use 24" wide vinyl every day and not having a 3rd roller has not been an issue. the only thing that DOES suck about the fan system is it puts out quite a bit of cold air on you if you sit close to it. BRRRR! My next venture with this machine is I want to try cutting window tint. wish me luck! lol
If you are going to be cutting window tint film then use a new blade.
Also ensure that you do you test cuts at the lowest pressure and work upwards until you get the correct pressure.
Window tint film has a backing normally that is thinner than the actual film being cut.
The opposite to vinyl.
You should not have any problems if you use a new blade.
Jerry from SignBlazer.
Now how did that happen?
I posted a reply to a question about tint film and it finished up here?
Mysteries of computers.
