Poot25 9 Posted June 4, 2010 Hey guys,using Inkscape to import image,traced the bit map and saved as an .eps file ,finally got it to open in SBE ,but it is just a Black square box ,when I click on it it asks me if use reader or scanner,have tried both still won't open up on screen.Like I said its just a black square box in the file preview.HELP and THANKS Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 4, 2010 sounds like it still has bitmap in it (raster) did you move the vector over and delete the original image before you saved it as an .eps? Share this post Link to post Share on other sites
Poot25 9 Posted June 4, 2010 Yes I did,now bear with me,as I just startecd using inkscape. I traced,then moved origional then deleted it and saved,but went to open and its just a block of black. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 4, 2010 you cannot OPEN in Signblazer, you must import. Are you dong that? Share this post Link to post Share on other sites
Poot25 9 Posted June 5, 2010 Yeah,saved in Ink then imported to SB,that is wherre the black is Share this post Link to post Share on other sites
tinaski 11 Posted June 5, 2010 can you post the file Share this post Link to post Share on other sites
Poot25 9 Posted June 16, 2010 Tinaski,sorry-been away for aq while and just thought to check this post-I will try to post the file up tonight when I get home,thanks Share this post Link to post Share on other sites
Poot25 9 Posted June 17, 2010 AND TO ADD INSULT TO INJURY,MY INKSCAPE PROGRAM HAS SOMETHING WRONG WITH IT SO I CAN'T FINISH THIS!!!!THANKS AGAIN J Share this post Link to post Share on other sites
cobbstickers 0 Posted June 17, 2010 go to "view" in the upper tool bar, then go down to "outline/wireframe" Share this post Link to post Share on other sites
Poot25 9 Posted June 17, 2010 Thanks I will try that if I can get inkscape to work,everytime I try to open it ,I get a microsoft alert that its had a error occur and won't respond,then closes program. Share this post Link to post Share on other sites
mars 45 Posted June 17, 2010 If you got a black square in SBE cobbsticker is suggesting using the outline/wireframe mode in SBE to see if your image is actually there, just hidden because it is black against a black square background Did you get it redrawn to your satisfaction and just having problems getting it into SBE? -Mike Share this post Link to post Share on other sites
Poot25 9 Posted June 17, 2010 Thanks for clearing that up,I thought it was in inkscape he was talking about,will try tonight to see if its there.Thanks J Share this post Link to post Share on other sites
