bret2973 0 Posted March 26, 2010 anyone have the face of the clock but backwards? I just got my clock to go backwards and wanted to get a face to go in the clock not really sure if I can do it or if it has to be a certain inch between numbers ect? thanks Bret Share this post Link to post Share on other sites
Team Satan 1 Posted March 26, 2010 heres two, all you gotta do is just reverse the file and cut clock face 01.eps clock.eps clock face 01.eps clock.eps Share this post Link to post Share on other sites
deth502 39 Posted March 26, 2010 just take any clock face and there should be an option to reverse it in whatever cutter program your using. the size and/or distance between anything dosent matter. a clock is read by the angle of the hand from the center, and no matter what size you scale it to , the angle will remain the same, as long as you do not distort the image. Share this post Link to post Share on other sites
knucklehead 530 Posted March 27, 2010 I don't think he's wanting it mirrored. I've seen those clocks, the one (1) is where 11 oclock would be, 2 is where 10 oclock should be, 3 is 9 and so forth. The clock runs counter clockwise. Share this post Link to post Share on other sites
deth502 39 Posted March 27, 2010 yes, exactly, and they are mirrored. the idea is for the clock to be read and appear normally in a mirror. started out in barber shops so the person looking in the mirror having their hair cut could read a clock on the wall beind them. Share this post Link to post Share on other sites
knucklehead 530 Posted March 28, 2010 OK, the ones I saw were just a regular clock that ran backwards. I guess the OP needs to chime in, and state what he's wanting. Share this post Link to post Share on other sites
JoeBlow 5 Posted March 29, 2010 This is what he's after. Share this post Link to post Share on other sites
mustangconv85 0 Posted March 29, 2010 here reverse clock.eps reverse clock 2.eps reverse clock.eps reverse clock 2.eps Share this post Link to post Share on other sites
