Signs Down Under
****NEED HELP WITH SIGNBLAZER FONTS****
Well have spent hours trying to recover fonts not showing in the text dialog box, have tried absolutely everything even though they show in SB fonts folder.
It all started when l tried installing more SB fonts that l have from previous software, thought it wouldn't be a problem since they are SB fonts but now l only get about 10 fonts in the dialog box and they look like the ones you get above the line for the last few fonts you have used, underneath those there is nothing.
I have tried loading into windows fonts as well but still no luck but they do show in corel x4 and Flexi 8.5 starter.
I have SBE on a desktop but have bought a new larger cutter and wanted to run everything off my laptop so l downloaded SBE from uscutters, my intention was to design everything in SBE and export into Flexi starter for cutting since SB doesn't have my cutter listed.
SB was running perfect with the 200 fonts you get with the download until l tried adding more SB fonts, l have even tried 4 fresh downloads hoping that would fix the problem.
I have used SB for a very very long time and this has never happended to me before, so if this cant be fixed SB is absolutely useless to me if l have no fonts.
I have posted here previous about the problem with no reply as yet, I'm very behind with my work at the moment because of trying to fix this.
I love this program but l think it's with great regrets l might have to delete SB and use corel for all my design work eventhough I'm not as efficient with it, SB is so easy to get around.
If anyone out there has any suggestions it would be greatly appreciated.
Gary.
did you install the fonts in teh windows font folder? that is where sb looks fo fonts. they must all be ttf fonts as well.
bb
Hi how ya goin, thanks for the reply.
Yes tried that but now they are all showing in corel and flexi.
I have SB on 2 desktops and they don't need to be in there SB has its own font folder under SBE, these are original SB fonts and they are ttf.
If you can see my previous post about the problem as well.
When l downloaded from usc fonts where sitting in that folder same as my other computers.
Give me a little while to get back to you.  I just added SB to my new laptop with Windows 7.  I had to copy ALL the fonts I added to SB while still on my old comp and paste them in the fonts folder on new computer.  I need to knock out some shirts first......Pat...
you stated SB doesn't have your cutter in the setup selection.   what cutter are you using.?  It really helps if you put your equipment names in your signiture so people don't have to keep asking.  Ya know, your computer ,cutter, software etc.  You can see it on other peoples posts at the bottom of their post.
The reason,  I was asking about your cutter,,  Is have you downloaded the FULL Signblazer version with ALL CUTTERS  Listed?  It is at the top of the SignBlazer thread,  Creation Pcut CT1200 is on it.
go to the Signblazer thread.     AT the top.  In darker blue letters  where it says  Full Version Signblazer download (All cutters).
Gary, here is what I did and seems to work fine.  I used my thumb drive to carry it from the old one to the new one.
1. In the old computer, got to my computer, C-drive, windows.  One of the folders there should be the fonts folder.  Right click and copy.  then go open your thumb drive and paste it there.
2.  Hook up thumb drive to new computer and open the fonts folder.  You should then be able to select all, then click copy.
3.  In new computer, go to computer, c-drive, windows and then fonts.  You will actually have to open the fonts folder.  Then paste the old computer fonts into that folder.
So  far, they have all shown up in my software.  I am only using SBE, so good luck with the other stuff.  It should recognize it though.
Pat.......
Hi have just checked the SBE on my desktop and could be the same one that's on the SignBlazer thread.
It has heaps of cutters on there including CT 1200 as you mentioned.
This is the one l paid for from Jerry Bonham in 2008 when he had his eBay store, l don't have a disc for it as back then it was a digital download and after l paid for it Jerry sent the activation code.
Could l copy the installation file from the desktop and load onto the laptop, if so would l still need to put in the activation code, not sure if l need to now. Do you think l could get my cutter to run off the CT 1200 option.
If l did do this does that mean it would no longer work on my desktop because back then if you put it on another computer it would no longer work on the original computer you loaded it on.
I also have SB pro with Hot Shot 5.0.28 with a upgrade disc to 5.1.19 that l have on a old windows 98 computer which uses a dongle key and have the lock and password numbers, bought this from Jerry years ago when he had his shop.
Too bad l couldn't use that in Vista.
Thanks to you who helped.
I have figured it out ;D l went to Hot Shot demo and in the dialog box l selected "Show all TTF fonts" then went back into Elements and sure enough there they all were.
There was no need to put them in windows fonts, now in the drop down dialog box l not only have heaps of window fonts but also show all of my 1200 SB fonts, the only exception is before it said sbf_ then the name of the font as well as the number, now it only has sbf_and what ever number the font is..... maybe if they were in the windows fonts this would fix it, will check that out but for now I'm just wrapped.
Hope this helps anyone having the same trouble.
Just have to get the cutter working in SB now !!
Thanks all.
Gary.
hi signs down under,u can use signblazer on vista,i use sbe06 pro on vista with dongle
i bought off jerry with one of his 1200king cutters when i went to his shop in melbourne/,
not working on my laptop yet with windows 7,maybe never will,i live in warrnambool, good luck.
G'day eagle 1,
Your's is 06 which l think was compatible with Xp and Vista.
Mine is SB Pro 05 on the disk is says Windows 95/98/NT4.
I have this still on a Windows 98 machine, mine is more of a software lock that plugs into l think by memory LPT1 which has a lock number then you run your cable from that to the cutter, l used to have a Roland camm 1 back then, l think pnc 1000 so not sure how l would get around that to run on Vista, don't think l can.
Ps.... l live in Sunbury just past the Tulla Airport.
