lmasse8326 1 Posted March 13, 2010 I have the pcut 630. Using 24" oracle vinyl, I am have a problem with the blade cutting perfect at one end and cutting through the vinyl on the other. I have adjusted the offset and pressure settings. I also replaced the blade. I have searched the forum, but haven't found this problem. I read that the blade holder needs to be oiled, I've had my machine for a year and haven't done this. Any help would be appreciated. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 13, 2010 another thing that has happened with this is . . .make sure the carriage is on the tracks and a roller has not jumped off. has it always cut this way? Share this post Link to post Share on other sites
lmasse8326 1 Posted March 13, 2010 Dakota, I checked the rollers and they are on track...everythings looks fine. No matter where I cut, the right side of the cutter has the deeper cuts. Thanks Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 13, 2010 has it always done that? Share this post Link to post Share on other sites
lmasse8326 1 Posted March 13, 2010 No it hasn't. I think it has something to do with changing the blade. I tried adjusting blade holder and it seems to be working better. Thanks for trying to help me. Share this post Link to post Share on other sites
jhelms 5 Posted March 14, 2010 Look at your cutter strip on the bottom under the blade iit is white plastic if you cut to deep you may have cut in to this may need to replace jhelms Share this post Link to post Share on other sites
lmasse8326 1 Posted March 14, 2010 j I believe your exactly right. I checked the strip and it is cut up in the same spot that it is cutting through the vinyl. Is this easy to replace? I have searched for forum and can't find any information on this. I appreciated your info Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 14, 2010 on a p-cut just snap the old one out and snap a new one in Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 14, 2010 you can purchase here http://www.uscutter.com/PCut-Laserpoint-Parts-Supplies_c_9.html Share this post Link to post Share on other sites
jhelms 5 Posted March 14, 2010 believe or not you guys posted the strip 4 to 5 weeks ago and you can teach an old dog new tricks I did remember it so now I was able to help another glad to helpGood luck jhelms Share this post Link to post Share on other sites
