mmracing601 0 Posted November 30, 2009 anyone know where to get this? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 30, 2009 A quick search shows 3m makes compatible reflective s In 2009 Fire Apparatus and Emergency vehicles will be subject to new guidelines in regards to reflective striping. The new standards call for striping on the front, sides and rear of all fire and emergency apparatus. A reflective type I tape or better is recommended. Type I tapes are also referred to as engineer grade reflectives. They are the most common and the most affordable class of tape and carry a 7 year outdoor life. Type 3 tapes are known as high intensity reflective tape and are more expensive but are still fairly affordable. They are rated for 10 years outdoors. We carry the type 1 and 3 reflective sheeting in both yellow and red and in both 4" and 6" by 150 foot rolls. We also carry a full line of other colors at our main reflective store. The two chevron tapes are further described below. The specifics of the new regulation are as follows: NFPA 1901 Standards For Retro Reflective Striping on Fire Trucks and Emergency Vehicles REFLECTIVE REQUIREMENTS FOR DOORS 14.1.6 Any door of the apparatus designed to allow persons to enter or exit the apparatus shall have at least 96 in.2 (62,000 mm2) of retroreflective material affixed to the inside of the door. 15.9.3.1* A retroreflective stripe(s) shall be affixed to at least 50 percent of the cab and body length on each side, excluding the pump panel areas, and at least 25 percent of the width of the front of the apparatus. 15.9.3.1.1 The stripe or combination of stripes shall be a minimum of 4 in. (100 mm) in total width. 15.9.3.1.2 The 4 in. (100 mm) wide stripe or combination of stripes shall be permitted to be interrupted by objects (i.e., receptacles, cracks between slats in roll up doors) provided the full stripe is seen as conspicuous when approaching the apparatus. 15.9.3.1.3 A graphic design shall be permitted to replace all or part of the required striping material if the design or combination thereof covers at least the same perimeter length(s) required by 15.9.3.1. REFLECTIVE REQUIREMENTS FOR THE REAR OF THE VEHICLE 15.9.3.2 At least 50 percent of the rear-facing vertical surfaces, visible from the rear of the apparatus, excluding any pump panel areas not covered by a door, shall be equipped with retroreflective striping in a chevron pattern sloping downward and away from the centerline of the vehicle at an angle of 45 degrees. 15.9.3.2.1 Each stripe in the chevron shall be a single color alternating between red and yellow. 15.9.3.2.2 Each stripe shall be 6 in. (150 mm) in width. 15.9.3.3 All retroreflective materials required by 15.9.3.1 and 15.9.3.2 shall conform to the requirements of ASTM D 4956, Standard Specification for Retroreflective Sheeting for Traffic Control, Section 6.1.1 for Type I Sheeting. 15.9.3.3.1 All retroreflective materials used to satisfy the requirements of 15.9.3.1 that are colors not listed in ASTM D 4956, Section 6.1.1, shall have a minimum coefficient of retroreflection of 10 with observation angle of 0.2 degrees and entrance angle of −4 degrees. 15.9.3.3.3 Any printed or processed retroreflective film construction used to meet the requirements of 15.9.3.1 and 15.9.3.2 shall conform to the standards required of an integral colored film as specified in ASTM D 4956, Section 6.1.1. REFLECTIVE REQUIREMENTS FOR OTHER PARTS OF THE VEHICLE 19.18.11 Where the design of the aerial device incorporates a knuckle, the knuckle shall be as follows: (1) Equipped with position lights or continuously illuminated by boom lights (2) Painted with reflective paint or provided with retroreflective Striping 19.21.4.3 All stabilizers that protrude beyond the body of the apparatus shall be striped or painted with retroreflective material so as to indicate a hazard or obstruction. Engineer grade or Type 1 reflective tape and is simply a solid color in daylight to the naked eye. When light hits the tape it is reflected to the source and the reflective tape lights up. Engineer grade type 1 tapes reflect at a rate of about 75 candlepower for white and less for other colors. This is the same material that you would typically find on emergency vehicles and makes up the majority of the reflective lettering that you see on fire apparatus. We carry the flexible engineer grade version because it will stretch making it perfect for applications on vehicles. High intensity or type 3 reflective tape is characterized by a honeycomb pattern (encapsulated lens reflective tape). Within each honey comb grid there are high concentrations of glass beads. This concentration of beads makes for a much brighter tape. High Intensity tapes reflects at a rate of around 250 candlepower for the white and less for other colors. Orange safety cones and road barrels use this material as well as many street signs. Quite a few fire departments prefer the high intensity type 3 material because it can be seen from further away and has a longer outdoor life. Share this post Link to post Share on other sites
ff958 0 Posted December 3, 2009 Our truck specs say the reflective vinyl is 3M Diamond Grade 983 series I think the colors are 71 and 72. You can set up an account thru 3m and order it straight from them. If I remember right it cost 288.00 for 6"x150' roll. They also charge 50 bucks for orders under 3,000.00. Share this post Link to post Share on other sites
