mailman 1 Posted November 19, 2009 After I finish a cut, using sign-cut my cutter cuts a box around my design, but only on 3 sides is there a setting to cut all 4 sides. I was not sure how to search for this answer. Thanks, Mark Share this post Link to post Share on other sites
pogo 0 Posted November 20, 2009 I had the same problem with a refine mh721. The solution was to set the driver in signcut to refine 1 hpgl. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted November 20, 2009 is the graphic slightly too large for it to cut the other side? Share this post Link to post Share on other sites
mr300s 1,272 Posted November 20, 2009 is the graphic slightly too large for it to cut the other side? I was thinking the same thing but I think that only happens with the graphtec? Share this post Link to post Share on other sites
hockeygirl 30 Posted November 23, 2009 If you're talking about the weeding box, signcut pro doesn't finish the final side of the box if you're only cutting 1 of. It'll do it correctly if you're cutting multiple. Share this post Link to post Share on other sites
CRD 9 Posted November 23, 2009 The weeding box always closes four sides as a rectangle if selected to do so. One side open never seen even if I cut one single job or multiple in line cutterwide. Paco Share this post Link to post Share on other sites
mailman 1 Posted November 26, 2009 Thanks everybody Share this post Link to post Share on other sites
JoeBlow 5 Posted November 26, 2009 Paco is correct, I think you have your vinyl width set too wide. Joe Share this post Link to post Share on other sites
CRD 9 Posted November 27, 2009 Mailman, Does it work as intended or not. Paco Share this post Link to post Share on other sites
Kimon 1 Posted November 29, 2009 Which side is incomplete as you face the cutter, right or left, top or bottom? Share this post Link to post Share on other sites
Cable Tech 0 Posted November 29, 2009 I have Flexi and MH-721 and mine doesn't finish the bottom weed line of the box either. I'm sure there is a fix but I haven't messed with it. I'm just happy my cutter is cutting properly with no major problems... Share this post Link to post Share on other sites
