Porkchopusn 0 Posted July 27, 2009 I understand there is a Copam 2500 driver that works with older versions of Corel Draw. It does not work with X4. Does anyone know if a new driver is in the works for Corel? Share this post Link to post Share on other sites
Guest kenya Posted August 1, 2009 ((Bump this again)) Share this post Link to post Share on other sites
Brandon_Davis 1 Posted August 1, 2009 Hey Pork... Are you trying to do a direct send via Corel Draw or are you using a cutting software plugin to work with your Copam? Share this post Link to post Share on other sites
Porkchopusn 0 Posted August 1, 2009 I am now using Cocut, but have a problem in cutting on the Copam. All dimensions on Copam are about 50% smaller than what cuts on the cutter. I have the same problem with SB. It appears that the Copam is incorrectly measuring the material. 8.5X11 inch paper is being measured at 150mmX225MM. Have you seen this problem in the past? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 1, 2009 possibly try a different driver,, as you know it is not the software. Share this post Link to post Share on other sites
Brandon_Davis 1 Posted August 1, 2009 I know that SBE has a setting that corrects for size differential and I have seen people with this setting enegaged causing this specific issue. The setting is in the setup window ... It is like size correction or something. Look for that. Share this post Link to post Share on other sites
Porkchopusn 0 Posted August 6, 2009 I will see if I can find it. Jim.. Share this post Link to post Share on other sites
