rdods 0 Posted April 22, 2009 I have the MH 871 and am trying to use it with flexisign 8.5. I am using the CE-2000-60 under the setup but the cutter only works with USB and even then, the poll size option doesn't work. Now I have a roland versaCAmm as a printer and all of my USB ports are used up. How can I get the MH 871 to work with the printer port or serial. Neither will detect the cutter and I feel like I have tried everything and have run out of options. Any help would be greatly appreciated. Ryan Share this post Link to post Share on other sites
firemalt 10 Posted April 22, 2009 I think the Refine 721 works with the Roland PNC_1000, doesn't hurt to see if it works for you. Share this post Link to post Share on other sites
MonkeyMeMe 8 Posted April 22, 2009 my refine 871 works with blaze port 6, and kingcut setting,I am usb,,, vista hope this helps, MMM Share this post Link to post Share on other sites
rdods 0 Posted April 23, 2009 I actually tried the PNC_1000 and it didn't work as well also it's my com ports that won't seem to work. When I plug in nothing comes up. Anyone know how to fix this? I don't have vista and am not to keen on it, also don't want to use blaze, iv'e used flexi for 10 years it's all I know and I paid out of my a** for it so I want to stick with flexi. Thinking about just ditching the CPU and buying a new one. Maybe the ports will work then. If anyone else can help, please!! Thanks Share this post Link to post Share on other sites
BannerJohn 1,324 Posted April 23, 2009 when you plug into the serial, you shouldn't get a pop up box. It's just there. Hook up to serial and try to cut. Share this post Link to post Share on other sites
rdods 0 Posted April 24, 2009 I have done this numerous times with the cables that came with the cutter, printer and serial cable. The only port that detects a connection is the USB and I don't have any left available. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted April 24, 2009 PM Ken or levi...one or the other should be able to remotely connect to your computer and get you set up right. Some setting is wrong. With serial all I ever had to do was hook it up, chose com1, load the right driver and go. Share this post Link to post Share on other sites
