sgreathouse 0 Posted July 31, 2007 I recently purchased a PCut and I can get the machine to cut but I think it is trying to cut my words in the wrong direction (or upside down...not sure). The carriage keeps running into the red stop button on the left side of the machine. For example I type "Stacy" and it just cuts the S and then stops. I am new to this so if any one has any suggestions on how to help I would appreciate it. Do I have some settings wrong? Share this post Link to post Share on other sites
kenimes 42 Posted July 31, 2007 You might check the size you are trying to cut. If it is too big for the size of the cutter you are using, you might run into this. Share this post Link to post Share on other sites
sgreathouse 0 Posted July 31, 2007 I don't think that it is. I have a 24 inch machine and the word I am cutting is no taller than 4 inches and no longer than 6 or 7 inches. It is like the orientation is off on my cutter and software. The best way I can describe it is Signblazer thinks the cutting is starting on the right side of the machine but it actually starts on the left side of the machine and then runs out of room. Does that make any sense? Share this post Link to post Share on other sites
kenimes 42 Posted July 31, 2007 Yes it does make sense. I will check into this as I have not heard of it before. Will keep you posted. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted July 31, 2007 when you first set up the Pcut,you should have been given the option to start in right,left,or center position.From what I have seen,not everyone in other countries starts at far right. Anyway,to solve this problem,all you have to do is set the origin to far right on the cutter itself.Origin being where the blade starts cutting. Share this post Link to post Share on other sites
Bruce SignBlazer Support 0 Posted August 1, 2007 It might be a couple of things. 1) Make sure you have selected the right cutter, I assume you have selected the Creation PCut CT630. This will specify the width of the cutter and should stop it hitting the left stop. 2) In the cutter panel in SignBlazer try selecting "Fit to Origin" and possibly "Rotate Across Vinyl". Share this post Link to post Share on other sites
sgreathouse 0 Posted August 3, 2007 Thanks...it was the origin. Share this post Link to post Share on other sites
kenimes 42 Posted August 3, 2007 Welcome to our forums, Bruce!!! You will make a wonderful addition. Share this post Link to post Share on other sites
