Days Won
498
Everything posted by MZ SKEETER
what version of Flexi are you using? 7.6, 8.1, 8.5, 8.6, 10?
make sure it has the USB dongle with it... that proves it is REAL LXI software and not some copy/pirated/cracked software. The USB dongle has the password for REAL versions.
sounds like you have your blade offset too high. run test cuts at .25 ,,,,most run around .25 + or - a little
If that bottom word listed FREINDS is supposed to be "FRIENDS" (as in pals, buddies) it is spelled wrong.
if you go to the UScutter.com website and find the Copam, go to the options below the cutter and you will see it is a Roland blade, 45 degree for most cutting, 60 degree for more detailed/fine work. Then just go to do a search for Roland blades. http://www.uscutter.com/Copam-CP-Series-Vinyl-Cutter-Professional-model-w-2-year-Warranty-B-CPCCP http://www.uscutter.com/index/page/search?FullText=Search+by+Product+%23+or+Keyword&FullText=roland+blades
very cool Bill
Yes, You can have two different versions of Flexi,on a computer. but you have to have the dongle in to open it. It is the password. Flexistarter is pretty ez. Not all the options of FlexiPro. It is just a cutting software basically.
That would be a price for Flexistarter8.6, Not FlexisignPro. 8.6 unless they are real dumb .... did you ask? In my Flexistarter8.6 it's listed under CE5000-40 CRP
Is this the cutter you have? or something different? http://www.graphtecamerica.com/ce5000-40.html
what size is your CraftRobo? Isn't there numbers on your machine? There are different Craft Robos... What version is yours? Personally I would not spend $4000 for new Flexi software. Buy a new cutter instead.
You are correct, wrong guy. wrong cutter. Sorry for confusion.
are you sure Signcut comes with a Graphtec? This guy is fighting to get his Graphtec CraftRobo running that he just bought on USCUTTER Amazon site. His old Flexi8.1 doesn't have the drivers. So if he got Signcut with his new Graphtec Craft Robo, he could use it.
your welcome glad you got it going..
You have to watch someone selling Flexi on CL. ALOT of pirated software. Did you ask what version and if it came with the USB dongle? REAL Flexi has a USB dongle password. Without the USB dongle it is cracked, pirated. The CE5000-40 CRP was on my Flexistarter 8.6, but not on Flexistarter 8.5 Also did you get a FREE 1 year Signcut cutting software, with your Graphtec?
I just use Flexistarter 8.6 with my Graphtec. Flexistarter 10 is out now. can be bought for about $130.00 You can design in inkscape FREE, just a thought. Did you just purchase, the Craftrobo? and did you get Signcut with it?
Illustrator Book Specifically For Decal Creation?
MZ SKEETER replied to MadStickerLab's topic in Adobe Illustrator
when I purchased my new CS2, It came with a book about an inch thick. Could walk you thru anything. No books coming out with later versions? -
alot of people have connected with windows 7 and no problems, it's done everyday, personally I don't upgrade, I stay back on an XP with XP backup computer, more stable, and can be found cheap on EBAY, you can find cheap XP desktops with serial port also, I have a computer that is totally dedicated to vinyl cutting. Nothing else. You will probably wish you had it on a serial port/KEYSPAN, before it's all over with, less dropping of data. The MH series cutters seems to also have limited memory, If it stops cutting large graphics you may want to purchase the 4 MB chip, goodluck.
have you gone step by step thru the newbie manual? You could also put a support ticket into UScutter and get tech support. http://www.customracingdecal.com/manuals/Noob-V4_9.pdf http://support.uscutter.com/index.php?/Tickets/Submit
found this on Signwarehouse Hello, HPGL/2 Command errors are common when you are using a parallel connection. Try switching to the serial connection and it should fix your problem. It should work with windows XP just fine. Try this and reply to this email if it doesn't work. Thank you for choosing Sign Warehouse.com Tech Support. Have a great day!
Signblazer (all cutter version) shows Graphtec Craft Robo in it. Which would be a FREE software. Or possibly maybe the Graphtec CE3000-40 might work You have to switch your cutter to HP-GL to work with regular software Flexi/Signblazer etc.
I don't know what you looked at , but I gave you a link for FREE software. here is the download http://www.mediafire.com/?oydmneru2zj
Correct not a Graphtec, But you can download the Signblazer all cutter version. VinyL EXPRESS GRC-61 is listed in the set up. download in first post
Guess I'm behind times, I have no idea what you are calling the rally look.
I don't add a curve to any, just apply it correctly with a straight stripe. It can be done. video below. http://www.youtube.com/watch?v=2r_oCiafDdQ
a little help please
MZ SKEETER replied to livinloudgraphics's topic in Creation PCUT Cutting Plotter Discussion
also make sure your pinch rollers are directly over the bottom grid roller.
