Days Won
640
Everything posted by Dakotagrafx
sure reminds me of that dipping process
Did you create a support ticket or contact support? could be a memory problem also
Hello from Michgian
probably the part about "Just purchased a MH-871 and it is cutting great". and from reading your post could the problem be with the usb hub you are using? have you tried to use the cutter plugged directly into the computer for better communication with no noise added by the hub???
Kevin - have you contacted USC support? have you done a support ticket?
MH871 Measurements/Feeding Question?
Dakotagrafx replied to KCR87's topic in USCutter Refine Cutting Plotter Support Requests
we do vinyl, shirts, mugs (sublimation) a little bit of everything -
Thanks J3werks
plenty strogn enough
Welcome aboard - love the avatar
US Cutter Introduces the ZenCut Green & Black
Dakotagrafx replied to Brandon_Davis's topic in Community Rules & Announcements
Thanks for the vid Vette -
Noticed on Ebay that signblazer is listed for a download and as included - what drives does this use in signblazer? -
did you submit the support ticket? they will run you thru checking the carriage and other checklist to narrow it down
1. Power Machine on 2. Feed roll through the back side, and line it up on both rulers at 7.5cm 3. use the offline button, and hit the down arrow until I have fed the vinyl all the way through its entire cutting length to make sure it is going to track properly. Press up arrow key to bring vinyl back to the original starting point at the front right of roll, then Hit origin button and cut -
won't be a problem
for those with usb only connections and SB freezing please read....
Dakotagrafx replied to cegglestn's topic in SignBlazer
The refine I had did not have screws holding it to the stand so that is why the ground wire worked. What machine do you have? -
Yes - pre feed the length of vinyl you will be cutting total to make sure it will track properly, the feed it back thru the cutter to the rear until you reach the front right corner and set the origin point -
got my curiosity Terry.
Thanks Mustandconv
MH-871 upgrade question
Dakotagrafx replied to tinaski's topic in USCutter Refine Cutting Plotter Support Requests
So what was the symptom when the mb went out? did it quit altogether, quit dropping the blade? quit communicating. I love a good mystery -
GETTING THE MAC TO READ THE ZENCUT GREEN 24"
Dakotagrafx replied to convictedthruChrist's topic in Mac Users Board
Levi - you should have these drivers if you are supporting this machine . . .Why direct the customer to find his own driver? This has been touted as being comparable to the graphtec CE5000-60 and we are looking for some feedback on the cutter. Now we have someone trying to give us something to go on and is told to go find your own driver??? Price on the machine is great compared to the competition for the same thing - is support?? -
Need to add area for Zencut help in vinyl cutter area
can some one please help vectorize this image,i am very frustrated
Dakotagrafx replied to michaelf32's topic in Vectorizing
replied in the other thread - you can hire drakesis to do it since no one has time right now (seen when you asked a while back also) -
Dakotagrafx replied to michaelf32's topic in General discussion
Michael - if no one has time to do it, I can recommend drakesis. I had him do one that I had been putting off due to it's complexity and he did a great job and reasonably priced. -
Used one for several months and it was a GREAT cutter. it cut smaller and better than any of the cheaper cutters.
