Days Won
174
Everything posted by haumana
Copam CP-2500 Setup Success
haumana replied to MalabarMcgyver's topic in Copam Cutting Plotter Discussion
If your rig has an open pci-e slot, you can give this a shot. https://tinyurl.com/4s7jaaau -
is it a parallel port, or serial port? -
Windows 11 is notorious for doing stuff like that. You might need to go into Device Manager and see if the com port was reassigned by Windows, and either reassign it back to what VM has it designated as, or reassign the port number in VM to match what Device Managger shows. If neither of those solutions work for you, unplug the cutter, reboot the computer and try to install it as if it were a new device you're adding to you computer. ... or if you happen to have a Windows 10, Windows 7 (my personal preference), or a Windows XP machine, you can use that to control your cutter.
cannot find the security key that matches the passcode
haumana replied to termagator's topic in USCutter Refine Cutting Plotter Discussion
Might be a good idea to export your most important files into some kind of generic vector file, so it can used in another program in a bind. -
'Aloha e Denis - Thanks for checking out the forum. I encourage you to register as a regular user, doesn't cost anything, but it will allow your posts to go up immediately instead of it being in queue, waiting for one of the moderators to approve it.
CE8000 can not get settings right
haumana replied to SR25's topic in GraphTec Cutting Plotter Support Requests
If doing a perforated cut, wouldn't that require a carrier sheet, just to make sure that a) there's a good surface under the blade to make the cut, instead of the forgiveness an trough would allow, and b) so that the material will no accidentally snag on blade from 'popping' up from being cut? Sorry, I don't do perforated cuts, so I'm just trying to get a better grasp of this. -
why aren't you using the blade holder to be situated over the cutting strip? -
I encourage you to register for this forum. It's free, and your posts will go up righ away. I broke the birds out to separate files, and zipped them up. What kind of software are you using for design or cutting? hummingbirds.zip
CE6000-60 with wrong firmware
haumana replied to djeans's topic in GraphTec Cutting Plotter Support Requests
Nice! Thank you for posting your 'work around,' no doubt your answer will help someone in the future. -
Power supply or main board. Was there a recent power outage?
Any one have recommendations on where to get aluminum sign blanks, preferably white? I'm specifically looking for 18" x 12" x 0.032. 0.040 if 0.032 isn't available. I only have one supplies shop locally, and they are super pricey, so I'm lookin to just pick-up blanks, and keep them in stock myself. Thanks in advance!
I will look into that. Thanks for the suggestion.
If I can get it to me under $12 per piece, that would be something I'd consider. Right now, I'm considering trying to order 50ish pieces, then will probably need to have it freight forwarded it to me.
This was the closest I could find.
Hey All. I'm back after 15 or so years.
haumana replied to Core Art Company's topic in Introductions
Welcome back! -
Aligning multiple pen colours
haumana replied to Phillup's topic in GraphTec Cutting Plotter Discussion
Welcome to the forum. Thank you for signing up. Glad you were able to figure out an aswer on your own. Thank you for posting your solution, as I'm sure it will help future users. If I may ask - what software, and platform (Win or Mac) you're using? -
Welcome to the forum. I encourage you to register as a user, then your post(s) will not need to wait for a moderator to clear it. I think I understand what you're trying to do. What you need to do is to color the different layers by different colors, then just cut by color. If I didn't interpret your concern correctly, then I ask that you post a picture or two of what's happening, so that other forum members can try to assist you.
Thank you for registering. Have you tried to select any of the MH cutters on the list and sent a test job to the cutter? There are many cutters out there that can run utilizing a different cutter designated in the settings.
DLB2 - Cutters will only cut vector lines, so if your circle, arrows and text are not vector, you cutter will not do a thing. I'd also encourage you to register with the forum, so that you're posts will go up immediately and not be in queue waiting for a moderator to approve it.
CE7000 with Cutting Master 5 Plugin all the sudden started not finishing cutting
haumana replied to ekgprodco's topic in GraphTec Cutting Plotter Support Requests
Did you computer do a Windows update? -
P Cut 630 won’t initialize
haumana replied to hopkinsrj's topic in Creation PCUT Cutting Plotter Discussion
what version of Windows are you running? make sure that the ComPort that Windows assigned to your cutter, matches the connection in the software. Each time you unplug/re-plug the USB, it's possible that Windows will assign it a different number. If you're running Windows 10 or Windows 11, then each update that Microsoft pushes runs the chance of knocking the cutter settings askew. for the most part, the majority of the regular volunteer forum members do take the time to read the original post in its entirety. -
MH871-MK2 not cutting
haumana replied to GeorgeGast's topic in USCutter Refine Cutting Plotter Discussion
If you are cutting through the vinyl and backing, then you are cutting into the cutting strip. The cut will literally be razor thin, but that's all it needs to start causing cutting problems. If you cutting strip has any slices through it, you should consider replacing it. A razor thin slice is all any of my machines needs to start giving me trouble. -
check the cutting strip. it doesn't take very many slices into it for it affect the quality of the cut. check the blade holder and blade holder carriage. I experienced low pressure due to a hairline crack in blade holder attached to the carriage. check the blade holder, that when you manually apply force to check the proper depth, you're actually getting a cut. -
Over Size Please Reset!
haumana replied to RRS1983's topic in TITAN 2 Series Vinyl Cutter Discussions
If we cannot seem to help you here, another place to try is the Sure Cuts a Lot Facebook page. Hopefully someone there might be able to assist you. There are only a handful of users here that run their cutters with a Mac, and the ones that I know who do, all have Graphtec machines and use their software. If you come across the fix, would you mind coming back and updating us? -
VinylMaster is Changing the cut size
haumana replied to Crazy_4_Moab's topic in VinylMaster CUT, LTR, PRO & DSR
it looks like the .031 might be attributed to line thickness. The two pics of the turkey have different line weights.
