aphem 0 Posted January 16, 2022 someone please help me fix this. after i do a default reset i have E01019 alarm on my CE7000-60 plotter. i have tried any ways i got from youtube but it not solve my problem. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 16, 2022 Cause: This error occurs when the blade tray was moved from side to side by the user after loading the media onto the plotter and with the rear plotter lever in the up position. if the error cannot be resolved I would contact graphtec directly for support . Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 16, 2022 Not sure where you found your info Dakota, But the error in the CE7000 user manual, says too heavy on the motor. Like they are trying to pull reflective or heavy vinyl. screen shot of error from CE7000 user manual Share this post Link to post Share on other sites
aphem 0 Posted January 18, 2022 There in no object disturbing the operqtion but it still Y position alarm, Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 18, 2022 Your motor may be dragging, running slow, etc, which may set off the alarm. What type of vinyl are you using? Is it a big roll that you are pulling from? That cutter can't be very old., Isn't it under warranty? Why haven't you contacted Graphtec tech support with your problem? That is who you should contact. Share this post Link to post Share on other sites
