1clo1 4 Posted March 15, 2021 I'm working on a project that I need registration marks, I want to know if there is a way to change the default marks to something different than the default. maybe a circle or square, something simple. I'm using VinylMaster DSR. Thanks Quote Share this post Link to post Share on other sites
bikemike 711 Posted March 15, 2021 If you are talking about layering vinyl, just make whatever you want for a mark, change the color to something different to everything else and cut the layer color and the mark color on every color. 2 Quote Share this post Link to post Share on other sites
1clo1 4 Posted March 16, 2021 how do I do that? I was referring to the option in the menu to add Registration marks, I can adjust them, but not sure how to change them to something easier to cut. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 16, 2021 What is the project? Layering vinyl? Just use the circle tool and place the circles where you want, Star, square, etc, whatever you want to use. You don't use the add registration mark tool. If your talking about printing registration marks and contour cutting, whole different project. So explain what the project is. 2 Quote Share this post Link to post Share on other sites
1clo1 4 Posted March 16, 2021 I am layering vinyl, I use the registration mark tool to add registration marks, if I just add a circle it cuts it as a separate color, not a registration mark. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 16, 2021 15 minutes ago, 1clo1 said: I am layering vinyl, I use the registration mark tool to add registration marks, if I just add a circle it cuts it as a separate color, not a registration mark. As bikemike mentioned many of us manually create our layering registration marks so we can place them where we want them (and use a shape we like, I like a plus mark). You can do like he said and make them a completely separate color layer from the rest and cut that color along with each color layer and all layers will have the circle. Not sure if there are options to change to regular mark or not. Alternatively you can make a set for one color layer and copy/paste them in place in a stack and change the color of each set to match the next color layer. This is more work but is how I do it most of the time. 1 Quote Share this post Link to post Share on other sites
1clo1 4 Posted March 16, 2021 Thanks guys, I will just leave the default ones, seem like more work to do all that. Quote Share this post Link to post Share on other sites
haumana 1,220 Posted March 16, 2021 13 hours ago, 1clo1 said: Thanks guys, I will just leave the default ones, seem like more work to do all that. You didn't answer the question as to what you are trying to accomplish. If you're layering vinyl colors, then a square, circle, diamond, or shape of your choice will be the easiest. It takes minimal effort and you will be doing it often if you're doing more than one color, so I suggest you start getting into the practice of it. If you're printing color on vinyl, and wanting the cutter to contour cut around that - then the registration marks should work. Only tweak them if they do not. Either way, it's work. It's what's necessary to get results, and also happens to be S.O.P. So get comfortable with the process for the results you're trying to achieve. Quote Share this post Link to post Share on other sites
1clo1 4 Posted March 16, 2021 I did answer the question, I said I was layering vinyl. i decided to just keep the default registration marks. Quote Quote Share this post Link to post Share on other sites
