isanabria79 2 Posted June 25, 2020 Hello, hope everyone is doing well during these crazy times. I have an old LYNX24 from Sign Warehouse that I got from a friend. It uses VE LXi software version 6.6v.1 with a dongle. I have it set up with a computer that runs Windows XP and it runs great still. I wanted to know if there is any way to use that vinyl cutter with other cutting software. I have Windows 10 x64 bit and would prefer to be able to use the LYNX with that computer since I also have a Silhouette Cameo. I do all of my designing in Illustrator so I only use the LXi software to cut what ever design I bring in from Illustrator. Don't know if I could use something like Sure Cuts A lot to be able to cut. I have a USB printer cable I can use but I'm willing to install a PCI Parallel Adapter Card to use the original cable it came with. Is this something that can be done or will I just need to keep 2 computers to be able to keep using the LYNX. Thank you very much for your help. Sincerely, Ismael. Share this post Link to post Share on other sites
haumana 1,221 Posted June 25, 2020 Have you looked up the spec's on for the LYNX24, or contacted Sign Warehouse? Have you tried to connect your Win10 to the LYNX24? Share this post Link to post Share on other sites
isanabria79 2 Posted June 25, 2020 5 minutes ago, haumana said: Have you looked up the spec's on for the LYNX24, or contacted Sign Warehouse? Have you tried to connect your Win10 to the LYNX24? No I haven't connect it because I'm scared it will damage it lol... I never thought about looking up the spec's.. what information should i be looking for in the spec's? I tried once to contact Sign Warehouse but they wouldn't help me because 1 - I wasn't original owner and 2 - because its really old and its not supported anymore. Share this post Link to post Share on other sites
haumana 1,221 Posted June 25, 2020 I'm not sure what kind of damage you think you could do. But you can just try to download whatever software you think you will want to use on your Win10 machine and plug in the cutter and see if it'll connect. Most of cutting software companies will offer a trial version of their software. You could also reach out to those companies and ask them if your cutter is compatible. This is from the Easy Cut Studio website of compatible cutters (which is pretty lengthy): Vinyl Express Lynx S-60 Vinyl Express Lynx S-30 Vinyl Express Lynx S-132 https://files.signwarehouse.com/tech_assets/manuals/Lynx_Manual.pdf Google is your friend, and will go a very long way with information. On a different forum, someone asked your same question - this was a link that was provided by someone who responded there. (I accept no responsibility for whether this software is compatible or not. It is up to you to do your due diligence). http://www.signgo.com/ Share this post Link to post Share on other sites
isanabria79 2 Posted June 25, 2020 3 minutes ago, haumana said: I'm not sure what kind of damage you think you could do. But you can just try to download whatever software you think you will want to use on your Win10 machine and plug in the cutter and see if it'll connect. Most of cutting software companies will offer a trial version of their software. You could also reach out to those companies and ask them if your cutter is compatible. https://files.signwarehouse.com/tech_assets/manuals/Lynx_Manual.pdf Thanks I ordered a PCI Parallel card. I'll try to connect it when It gets here on the 26th and see what it does. Also thanks for the manual, I actually still have the original manual. Share this post Link to post Share on other sites
haumana 1,221 Posted June 25, 2020 Another thing you can try ... install the Lynx software on to your Win10 machine. There are some pretty old software out there that (by some miracle) can run on Win10. It's an oddity, but it's worth a try. I mean SBE runs on all kinds of versions of Windows 1 Share this post Link to post Share on other sites
isanabria79 2 Posted June 27, 2020 On 6/24/2020 at 9:45 PM, haumana said: Another thing you can try ... install the Lynx software on to your Win10 machine. There are some pretty old software out there that (by some miracle) can run on Win10. It's an oddity, but it's worth a try. I mean SBE runs on all kinds of versions of Windows I tried to install the software but the dongle doesn't work on the windows 10 computer. I tried it again on the win xp computer and it works fine.. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 27, 2020 remember on the windows 10 computer you have to also install the sentinel software so it can read the dongle. not sure if it will work but lots of people have forgot that step when changing computers Share this post Link to post Share on other sites
isanabria79 2 Posted June 28, 2020 On 6/26/2020 at 5:41 PM, Dakotagrafx said: remember on the windows 10 computer you have to also install the sentinel software so it can read the dongle. not sure if it will work but lots of people have forgot that step when changing computers Thanks, I checked on that and downloaded the ones for HASP but i don't know what i need to do. it gives options but when you click ok it just closes. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 28, 2020 11 hours ago, isanabria79 said: Thanks, I checked on that and downloaded the ones for HASP but i don't know what i need to do. it gives options but when you click ok it just closes. That could be a problem if the hasp (the used hasp and sentinel in the past) it has to be able to communicate with that dongle to work Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 28, 2020 I found this list of Aladdin Hasp drivers, maybe it can help you. https://www.driverguide.com/driver/company/Aladdin/index.html#mostpopular 1 Share this post Link to post Share on other sites
isanabria79 2 Posted June 29, 2020 4 hours ago, MZ SKEETER said: I found this list of Aladdin Hasp drivers, maybe it can help you. https://www.driverguide.com/driver/company/Aladdin/index.html#mostpopular Thanks i went through all the ones that said HASP4 and kept getting errors until i found 1 and the dongle now lights up but the LXi software still telling me it needs a dongle to run Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 29, 2020 Did you reboot your computer after you installed the driver? Leave the dongle in the computer. I had an old Flexisign 7.6 which I put on Windows 7, After I rebooted the computer, it worked. That is all the info that I have 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 29, 2020 2 hours ago, isanabria79 said: Thanks i went through all the ones that said HASP4 and kept getting errors until i found 1 and the dongle now lights up but the LXi software still telling me it needs a dongle to run just to check all the boxes - you got the product id and password for the software too - right? Share this post Link to post Share on other sites
isanabria79 2 Posted July 1, 2020 On 6/28/2020 at 6:52 PM, MZ SKEETER said: Did you reboot your computer after you installed the driver? Leave the dongle in the computer. I had an old Flexisign 7.6 which I put on Windows 7, After I rebooted the computer, it worked. That is all the info that I have Yes i tried that no luck Share this post Link to post Share on other sites
isanabria79 2 Posted July 1, 2020 On 6/28/2020 at 7:19 PM, Dakotagrafx said: just to check all the boxes - you got the product id and password for the software too - right? Yup that too... still nothing. i tried cutting with the sure cuts a lot trial software and i got it to work.. I think ill just pay the 59 bucks and get it. I have a silhouette also with i could use that software with the lynx. Share this post Link to post Share on other sites
isanabria79 2 Posted July 1, 2020 Thanks you everyone for your help. the vinyl cutter works with sure cuts a lot so ill just be buying that. 2 Share this post Link to post Share on other sites
haumana 1,221 Posted July 2, 2020 Have you tried Sign Blazer? Share this post Link to post Share on other sites
darcshadow 1,627 Posted July 2, 2020 On 6/27/2020 at 11:55 PM, isanabria79 said: Thanks, I checked on that and downloaded the ones for HASP but i don't know what i need to do. it gives options but when you click ok it just closes. That screen there is basically an instruction screen. It's telling you the commands line options. You would need to open a command/terminal window then type Hinstall -i. I would guess, if you scroll down that window there is an example. Share this post Link to post Share on other sites
