alexander kennedy 0 Posted June 16, 2020 I WOULD LIKE TO KNOW EXACTLY HOW TO USE CRI CUT VINYL WITH A USCUTTER.AFTER MY FIRST CUT THE VINYL WOULDNT ADHERE TO THE SHIRT Share this post Link to post Share on other sites
alexander kennedy 0 Posted June 16, 2020 MAYBE IM JUS USING THE WRONG BRAND? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 17, 2020 are you using a vinyl made for shirts - are you using a heat press to apply it? Time, pressure and Temp are all 3 important for HTV 2 Share this post Link to post Share on other sites
haumana 1,221 Posted June 17, 2020 If you provide us with the a little more information we can attempt to assist you better. Are you using just regular vinyl? If so, that's not the right type, unless you're going for a single use, then peel off and throw away at the end of the day. If you're looking for a more permanent vinyl, then you need to get yourself some heat transfer vinyl (HTV - as mentioned above). Do you already have a heat press? If so, then let us know the model and the steps that you've taken to get your results. ... and on a more trivial note - I'd also recommend that you use don't leave posts in all caps. 1 Share this post Link to post Share on other sites
mfatty500 455 Posted June 17, 2020 YEAH WHAT HE SAID^^ Share this post Link to post Share on other sites
