Scratchthejeepguy 77 Posted December 10, 2019 My US Cutter vinyl cutter seems to be cutting too deep. I didn't know how to set the depth of the blade, but I saw an image on US Cutters website that showed me how far the blade should be sticking out so I just copied that... 2 Share this post Link to post Share on other sites
darcshadow 1,626 Posted December 10, 2019 Good idea, how'd you get the holder at that angle? 1 Share this post Link to post Share on other sites
bikemike 711 Posted December 10, 2019 Did you cut the holder in half like the picture? If not, that could be the problem. 1 Share this post Link to post Share on other sites
Scratchthejeepguy 77 Posted December 10, 2019 51 minutes ago, darcshadow said: Good idea, how'd you get the holder at that angle? Duct tape. Share this post Link to post Share on other sites
Scratchthejeepguy 77 Posted December 10, 2019 13 minutes ago, bikemike said: Did you cut the holder in half like the picture? If not, that could be the problem. No I didn't... Thanks, I'll try that! Share this post Link to post Share on other sites
arty-rc 719 Posted December 10, 2019 look up the posts made by MZ Skeeter for the proper way to set a blade. Works every time. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 10, 2019 posted hundreds of times on the forum. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should just barely see and feel your blade tip out of the blade holder. 2 Share this post Link to post Share on other sites
Scratchthejeepguy 77 Posted December 11, 2019 21 minutes ago, MZ SKEETER said: posted hundreds of times on the forum. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should just barely see and feel your blade tip out of the blade holder. So it's not supposed to stick out as much as it is in the picture I posted above...? : ) Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 11, 2019 56 minutes ago, Scratchthejeepguy said: So it's not supposed to stick out as much as it is in the picture I posted above...? : ) No way. You should just barely see and feel the blade tip out of the blade holder, as stated. You only cut with the very tip of the blade. Vinyl is only 2-3 mil thick. 1 Share this post Link to post Share on other sites
Scratchthejeepguy 77 Posted December 11, 2019 Actually, this thread was just a joke...... I saw the pic that US Cutter has of their blade holder and thought it was funny. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 11, 2019 29 minutes ago, Scratchthejeepguy said: Actually, this thread was just a joke...... I saw the pic that US Cutter has of their blade holder and thought it was funny. they also still have videos and instructions to use 1/2 a credit card depth which we all know is 10 times too much blade - the old timers that stay around and read every single post helping newbies have gotten hundreds of people cutting correctly on the weekends and nights when the main office is closed - - - day after day, week after week, month after month - same story. Share this post Link to post Share on other sites
