Sue2 907 Posted December 30, 2016 I have this Mug Press that came along with my Hotronics 16x20 Swing T-shirt Press several years ago... got lucky & found them locally on Craig's List! What supplies do I need to purchase to start making sublimated mugs...and where is the best source. Or is this antiquated equipment.......the only name I can see on it is OMRON H3G Sue2 Share this post Link to post Share on other sites
Wildgoose 4,110 Posted December 30, 2016 Check with Conde. Share this post Link to post Share on other sites
Dakotagrafx 7,162 Posted December 30, 2016 If it heats evenly then just get a Ricoh sawgrass setup from uscutter and go to town. Personally I like the wraps better as you dong get the heat loss thru the bottom and handle causing fading in those area but lots of people use them Share this post Link to post Share on other sites
signyouup 176 Posted January 2, 2017 Omron is who makes the timer. Share this post Link to post Share on other sites
Dakotagrafx 7,162 Posted January 2, 2017 26 minutes ago, signyouup said: Omron is who makes the timer. not sure but why not just use a cheap cooking timer? magnetic Share this post Link to post Share on other sites
Sue2 907 Posted January 2, 2017 8 hours ago, signyouup said: Omron is who makes the timer. Yup...that's where "Omron" is located...on the timer frame. The clamp handle has KAKUTA F250 embossed into the bottom.... but no indication of a manufacturer. I guess I will have to test it to see if it heats evenly. Sue2 Share this post Link to post Share on other sites
