DNA_Vinyl 262 Posted May 20, 2016 My first vehicle! (nothing fancy) I tried the wet install method and I can tell you if you haven't done it before...DO IT! super easy...a lot better than the normal dry install IMO. 3 Share this post Link to post Share on other sites
Jburns 239 Posted May 20, 2016 looks good! what product did you use for wet method? Also paper app tape? Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted May 20, 2016 I used the regular app tape, the clear. I used 16oz water and 2 drops of dish soap. perfect! Share this post Link to post Share on other sites
Jburns 239 Posted May 20, 2016 awesome- i knew there was another alternative to app fluid. 1 Share this post Link to post Share on other sites
Moody Blue 505 Posted May 20, 2016 If you don't want to wet install check out the wrap vinyl...3M 1080 or Avery SW900. Both have an "air release" grid on the back and temporary adhesive that will allow the decal to be placed/replaced and applied dry without wrinkling or bubbling. Its a bit thicker than your regular vinyl but the outcome is great. 4 Share this post Link to post Share on other sites
mrfibble 77 Posted May 21, 2016 looks great well done Share this post Link to post Share on other sites
tshirtn00b 12 Posted May 27, 2016 Moody Blue, can you recommend a supplier for the Avery and 3M vinyls? I don't see them on uscutters site. Thanks. Share this post Link to post Share on other sites
Moody Blue 505 Posted May 31, 2016 Moody Blue, can you recommend a supplier for the Avery and 3M vinyls? I don't see them on uscutters site. Thanks. I buy those at Fellers and Metro Restyling https://www.fellers.com/ http://www.metrorestyling.com/ Share this post Link to post Share on other sites
603decals 1 Posted June 2, 2016 I just used some of the the 3M 1080 from metrorestyling and it is great! Share this post Link to post Share on other sites
JuanG 2 Posted June 6, 2016 Hello all, I've never had a preference one way or the other, wet or dry. I will say, however, I have been putting decals on motorcycles for years and wet method saves me sometimes because of the contours. I used 12 oz water, 2 drops dish soap and a cap full of rubbing alcohol. Some formula I got about 15 years ago and have used ever since. Just FYI 2 Share this post Link to post Share on other sites
raduck77 0 Posted June 9, 2016 Looks great! I'm new to vinyl and have never heard of applying it "wet". Is it the same basic idea as applying window tint? Share this post Link to post Share on other sites
DNA_Vinyl 262 Posted June 9, 2016 Looks great! I'm new to vinyl and have never heard of applying it "wet". Is it the same basic idea as applying window tint? Dunno...never put tint on. Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted June 12, 2016 That Install looks great. I use the recipe below. I make a gallon at a time and use it to clean and everything and install with. I use a gallon jug of (Crystal Geyser) water Empty out enough to add 1 cup 70% rubbing alcohol, 10 drops ofbaby shampoo. Leave out the alcohol if for digital prints. Which I did not know about the last part on digital prints. Share this post Link to post Share on other sites
