Appleuser 5 Posted March 9, 2015 Good news!!I asked graphtec america for the firmware 1.70. Since this firmware is not on their website.So I got it emailed to me.Flashed the firmware without any problems. And did a reset of the machine. Loaded some work into graphtec studio and started cutting. Work without any errors. Did some testing and more testing. NO ERRORS AT ALL!! YEAH!! Finally I got it working again Hope it will work all time.Does your graphtec machine work?? Do nothing AND DONT DO ANY FIRMWARE UPGRADING!!!!Thanks 3 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 9, 2015 Glad you got it going good.... Share this post Link to post Share on other sites
mr300s 1,272 Posted March 10, 2015 Good glad you got it going good and yes " don't fix what ain't broke" I heard that somewhere 3 Share this post Link to post Share on other sites
Appleuser 5 Posted March 20, 2015 well, a little update. I dont get any error messages, but I often get random cuttinglines over the work. Any ideas? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 20, 2015 Hard to say without really checking the files you are cutting... Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 20, 2015 gotta be an apple thing - never had that with any of my graphtecs what software are you using to cut with? Share this post Link to post Share on other sites
Jesse F. 7 Posted March 20, 2015 The CE-6000 is usually pretty straight forward on a Mac as well as a PC, although most plotters we've found to just work better on PC across the board. When was the last time you ran an update for your OS out of curiosity? From the sound of it though it does seem like it could potentially be a Mobo issue, especially if you've rolled the firmware back and it has been doing this across multiple computers. I'll pick our Tier 3 tech's brain on this one and see if there's anything else we can think to check. Share this post Link to post Share on other sites
Appleuser 5 Posted March 20, 2015 I use mac, and there have been no problem using mac.I have also tried on a pc, same problem there.I can make a new file, enter a text (20x30cm) and when I cut, it make random cut lines.. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 20, 2015 I use mac, and there have been no problem using mac.I have also tried on a pc, same problem there. I can make a new file, enter a text (20x30cm) and when I cut, it make random cut lines.. Post some of those files up... Show some photos of your problem.. What software are you designing and cutting with? Share this post Link to post Share on other sites
Appleuser 5 Posted March 21, 2015 Here is the example file http://www.lasertech.no/test.gstudio I using graphtec studio or even illustrator Picture of what do happends.second line is how it can cut the file. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 21, 2015 I thought maybe you had actual pictures of vinyl, where it is random cut. Have you tried the cutter on HP-GL language? You can use the Signcut.com trial for 1 week. Free trial at top of page. It is for Mac. http://www.signcutpro.com/ Share this post Link to post Share on other sites
Appleuser 5 Posted March 21, 2015 No, I will try signcut... Share this post Link to post Share on other sites
Appleuser 5 Posted March 24, 2015 Well, same problem there. do random cut lines in signcutI guess I need a new mainboard.emailed graphtec and I am so lucky that graphtec will only send out to U.S. Addresses. and I live in Norway.Anyone knows what a new motherboard for the CE6000-60 cost? If anyone can check, I would be gratefull PN U792600750Thanks Share this post Link to post Share on other sites
Appleuser 5 Posted April 12, 2015 Just an update!Have not got new mainboard. But I have kinda solve the problem for now. I design in AI of Graphtec studio, and power on the cutter. Then I press "Send to cutter" It do cut without any problem. When fnished cutting, I power it down. And starts all over again for each cutting. But IF it has power on all time, it starts to do random cutting For now, I am happy... Share this post Link to post Share on other sites
Appleuser 5 Posted April 24, 2015 New updateThe Graphtech CE6000-60 cutter works perfect now with restarting after each cutjob. Soon the power is on all time, it do random cuts.. Any ideas?? regards Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 24, 2015 call graphtec - they will probably have you send it in - that is not normal Share this post Link to post Share on other sites
fustratedinhawaii 71 Posted May 1, 2015 Appleuser, do you have an update? Share this post Link to post Share on other sites
Appleuser 5 Posted May 25, 2015 Well it has the same issue with random cuts Share this post Link to post Share on other sites
jump 0 Posted June 5, 2015 Hello, Which updated the CE6000-60 with the v2.20 fimware successfully? Share this post Link to post Share on other sites
Appleuser 5 Posted June 7, 2015 Have not tried that formware. Just v2.10 and same problem, so I downgraded back to v1.7. And Graphtec will not help me. Share this post Link to post Share on other sites
Appleuser 5 Posted June 25, 2015 Change motherboard and all good Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 25, 2015 Change motherboard and all good Don't upgrade it again.. 2 Share this post Link to post Share on other sites
Eashman 0 Posted August 1, 2016 many people have had this error and i think I found the fault at my end as i use my ce6000 on a main pc thought ill try my laptop and its worked no problem after trying difrent software etc found its been the driver fault not the firmware 2.20 as back dated my pc and all is well up to now no errors at all what was going on when not linked to pc plotter own test fine soon as conected to pc iit tryin proseesss something not even there to the buffer and was like ghost the fast feed media out this may help others out will post on forum see feed back its a hobby for me not a bizzyness were people need working every day thanks Ian Share this post Link to post Share on other sites
