kitconceptz 1 Posted October 30, 2013 I have this 24 vectored image, I'm trying to make it where the green portion of the 2 has just an outline and the inside gets cut out and where the 2 and the 4 are cut as one piece (that way it doesn't cut thru the 2 when printing) Any help is appreciated, thanks! 24.eps Share this post Link to post Share on other sites
Dawn's Design 403 Posted October 30, 2013 024.svgThis is what I came up with. Share this post Link to post Share on other sites
kitconceptz 1 Posted October 30, 2013 Anyway to make the 2 and the 4 one cut rather then having it where the 2 cuts thru the 4 and vice versa? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 30, 2013 You have to weld when you cut. to make the 2 and 4 the same object Share this post Link to post Share on other sites
Dawn's Design 403 Posted October 30, 2013 24.svgDid this work? Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 30, 2013 What program are you using? In Inkscape, this is how I would do it. First select the 2 and the 4 and do a path->Union The green section is placed on top of part of the two so I would duplicate the green section and select it and the 2 and then do a path->difference I'd again duplicate the green section, change the new to a different color, then do path->inset. Repeat as necessary to get the thickness of green outline you like. Then select the green section and the small internal section and do a path->difference Share this post Link to post Share on other sites
dwp99 283 Posted October 30, 2013 Here you go. I welded the 2 to the 4 and cut the overlap of black from under the green now the green is one part and the 24 is one piece 24.eps Share this post Link to post Share on other sites
kitconceptz 1 Posted October 30, 2013 Perfect!! Thanks alot guys!! Would you happen to be able to help with this one, it's my buddies company....thanks again in advance Share this post Link to post Share on other sites
kitconceptz 1 Posted November 13, 2013 Would anyone happen to know what font the rail would be typed in, or can anyone help with vectorizing that rail portion? Thanks Share this post Link to post Share on other sites
