Popeye 0 Posted June 29, 2013 I'm trying to contour cut on my PCut 630 using SB Pro.. Every time I try to "cut a print" it locks up the software. Thanks for the help Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 29, 2013 Had you been successful doing this before? If so, was there any change you made to the computer system? Share this post Link to post Share on other sites
Popeye 0 Posted June 29, 2013 No, I haven't... never really had a problem with the software before until trying this feature Share this post Link to post Share on other sites
Rodger 527 Posted June 29, 2013 Reading into your post .... it sounds like you have Elements and trying to cut with the Pro/Hot Shot demonstration stuff . You can design in the higher end versions that can be accessed in Elements , but you can't save the file or cut from it . Am I guessing close ? More info is needed to help . Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 29, 2013 Reading into your post .... it sounds like you have Elements and trying to cut with the Pro/Hot Shot demonstration stuff . You can design in the higher end versions that can be accessed in Elements , but you can't save the file or cut from it . Am I guessing close ? More info is needed to help . His signature says otherwise,,,, Roger, just throwing that out there, because I noticed it.. SB 6.0.11 Pro w/dongle 1 Share this post Link to post Share on other sites
Popeye 0 Posted June 29, 2013 Correct.. I have Pro w/Dongle. Another thing is the jog buttons operate the carriage and roller completely backwards. I tried the same thing using a version of elements I have... same driver... same file. The jog buttons work correctly and after I set the reg marks and tell it next it give another window asking for redeye offset.. I set that to 0.001 and hit cut and it does. Not sure why they are not the same and why it doesn't work correctly with Pro.. Share this post Link to post Share on other sites
Rodger 527 Posted June 29, 2013 Good catch Skeet , Thanks . In that case " i dunno " ... SignBlazer Elements freezes on me at times also . But every software I have tried does that at times . SCALPro & SB seems to do it when I go back and forth from design to cut screen amd make many changes . Probably a combination of all the stuff I have going on my computer while designing . It is not a problem , I know to deal with it . I would suggest to contact member " Moby " Mike O'Brian , who services and sells higher end SignBlazer products . Seems to me he sells Pro/HotShot with dongle for $500 . He is involved in developing the evolved SB software . Share this post Link to post Share on other sites
Popeye 0 Posted June 29, 2013 I appreciate the information.. do they have a support forum? Share this post Link to post Share on other sites
Rodger 527 Posted June 29, 2013 YW . No support forum . Still working on releasing it , Share this post Link to post Share on other sites
