Ericjgidney 0 Posted May 13, 2013 I could use someones help. I usually have no issues cutting graphics but when it comes to cutting the raiders logo it pulls off vinyl while cutting. I changed blade offsets, changed blades, changed angle blades, changed vinyl both thicker and thinner and nothing seems to work. This is for a small project like a 4x4 picture. This would not be an issue for a decal but I am using for etching and so it eats the things I need to keep. Sorry and the cutter is an sc model Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 13, 2013 usually lifting vinyl is caused by too much blade. Also clean that blade now. with alcohol, to get all the adhesive off of it. 1 Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 13, 2013 And a very small drop of 3m oil keeps it moving free 1 Share this post Link to post Share on other sites
Ericjgidney 0 Posted May 14, 2013 Thanks will try these suggestions Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 14, 2013 http://forum.uscutter.com/index.php?/topic/39196-blade-depth/ Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 14, 2013 Probably your design has fine / small details -- go into your design and check the nodes. Share this post Link to post Share on other sites
