bradsc1954 7 Posted April 20, 2013 I have a design that was create in Adobe Illustrator. One line of text I warpped. When I send the document to the cutter that text that is warped in Illustrator is straight when sent to cut master. Any suggestions on how make the warp so it doesn't get effected when being sent to the plotter? Brad Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 20, 2013 not exactly sure but what if you convert the text to lines before sending it to cutmaster 3 Share this post Link to post Share on other sites
bradsc1954 7 Posted April 21, 2013 I have converted the text to outlines and it still outputs it straight. Along with saving it as an eps and a pdf. When I open it in cutting master the text is staight. Share this post Link to post Share on other sites
68Blkbrd 2 Posted September 25, 2013 When you view in keyline mode although you converted to paths you will still see that the text does not have the warp effect you desire. You have to expand appearance under the object drop down menu. It will then cut with the warp effect you desire. Share this post Link to post Share on other sites
68Blkbrd 2 Posted September 25, 2013 If you view in keyline mode although you converted to paths you will still see that the text does not have the warp effect you desire. You have to expand appearance under the object drop down menu. It will then cut with the warp effect you desire. Share this post Link to post Share on other sites
