extremerodeo 0 Posted March 3, 2012 I am new to using cutters and just recived mine. We cant find our cutter in the set up cutter drop down. The model is a SC 34" and there is nothing there that remotly looks like the correct 1. Please help Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 3, 2012 I am new to using cutters and just recived mine. We cant find our cutter in the set up cutter drop down. The model is a SC 34" and there is nothing there that remotly looks like the correct 1. Please help Your cutter is a LiYu start here Start.uscutter.com Share this post Link to post Share on other sites
markvvq 14 Posted March 3, 2012 are you using the 1 year license to sign cut? If so you have to D/L and install the extra drivers from their website! Mark Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 3, 2012 are you using the 1 year license to sign cut? If so you have to D/L and install the extra drivers from their website! Mark they are in the Flexi category, so I am assuming they are using Flexi. I could be wrong though.. Share this post Link to post Share on other sites
Rodger 527 Posted March 3, 2012 Skeeter , I do remember you being WRONG 1 time !!! The 1 time you thought you were wrong .... you were not !!! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 3, 2012 Skeeter , I do remember you being WRONG 1 time !!! The 1 time you thought you were wrong .... you were not !!! LMAO Roger!!!!!!!! :wacko: Share this post Link to post Share on other sites
markvvq 14 Posted March 3, 2012 they are in the Flexi category, so I am assuming they are using Flexi. I could be wrong though.. I missed that....I'm sure you are correct! I had the same problem when I got my TC. Share this post Link to post Share on other sites
extremerodeo 0 Posted March 7, 2012 How do I know Bites Per Second, Data Bites, Stop Bites, Flow Control, and Parity? Share this post Link to post Share on other sites
extremerodeo 0 Posted March 7, 2012 This is all that the instructions give me Items Contents Cutter Inertia rotating cutter Plotter Ball-point water pen Mechanical resolution 0.0254mm/step Buffer capacity 1MB Repeatability 0.127mm Motor type Step motor, driven by detailed constant current Interfaces 1、RS—232 serial port 2、CENTRINIC parallel port Byte form 8 data-bit,1 stop-bit Commands set DM / PL Power requirements AC220V/110V(±10%) 50Hz—60Hz Environmental temperature 0 to 35℃ Environmental humidity 5% to 95%(without water-drop) Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 7, 2012 I gave you the instructions to set up in post #2 http://start.uscutter.com/ Share this post Link to post Share on other sites
extremerodeo 0 Posted March 7, 2012 I see that Skeeter and thats all the info given to me on the guide. Also can i send Jobs thru just on Flexi or do I need to send it thru illustrator? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 7, 2012 when you click the start link that I gave you, did you choose your vinyl cutter? then your operating system?, and walk thru the rest of the setup? Then choose Flexi and go thru the Flexi setup? To check the How do I know Bites Per Second, Data Bites, Stop Bites, Flow Control, and Parity? You have to go into your computer device manager and check the properties of the comport # you are using. You have to import your vector image into Flexi to cut. Share this post Link to post Share on other sites
extremerodeo 0 Posted March 7, 2012 i have it all ready and set up but now its telling me it cant open port? Share this post Link to post Share on other sites
joshuanicholas450 1 Posted March 14, 2012 i have it all ready and set up but now its telling me it cant open port? try moving the usb to a different port and reinstall the driver. make sure you uninstall the first one. i had to do that to get mine to work. Share this post Link to post Share on other sites
