Guest
SignBlazer Elements downloads and other info
Guest
SignBlazer Elements Installer: http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=30&nav=0,4,12
SignBlazer Elements Update: http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=26&nav=0,4,12
**note** Install this update after you run SignBlazer Elements Installer. This update is necessary if you are trying to use the RainDrop Craft Cutter with SignBlazer Elements.
SignBlazer Elements Manual: http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=31&nav=0,4,12
SignBlazer Elements help file: http://support.uscutter.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=39&nav=0,4,12
SignBlazer Elements knowledge base: http://support.uscutter.com/index.php?_m=knowledgebase&_a=view&parentcategoryid=5&pcid=0&nav=0
If you have anything useful to be added to this post please let me know and I will edit it into the original post.
Will the Installer or the Update version bring SBE out of Trial mode?
What is the status of Sign Blazer and its' trial Mode? Can any thing be done to 'fake' a registration, etc?
John
Hey John ,
The whole story in the SIgnBlazer section . Trial mode is forever unless you use the crack that is 1 of the threads . It uses 6.0 instead of 6.24 ( guessing #'s from memory ) All it does is take the 3 nag screens away . I like the newer version & don't mind clicking thru the 3 screens . Otherwise , the trial mode is exact to Elements version . Personally I think there is" non trial " versions available , but that stays "underground " . The are torrent site that claim Hot Shot , Pro & non trial versions , but I was told by a knowledgable member here to stay away from them unless you have GREAT security on your computer .
Hey John ,
The version I have posted with cut to print is version 6.21.
There are no other "Cracked versions" if their were I would have posted it thus why I did what I had to do :thumbsup:
I have yet to find something different on 6.24 from 6.21, ne one want to let me know if any, what and/or how valuable it is thats changed?
All the sites that show you "hotshots" etc are just using search string megtag bots.
OK thank you, i send a donation to get this program to a member on this forum hope it doest take to long
I have SBE installed on my desktop for vinyl cutting. I wanted to download a second SBE to my laptop for working on the road. I saved the file and when I went to install it, a warning box opened and said that only one installed program is allowed. If a second one is installed, neither will work anymore. I did not try to install it for rear of being unable to use either program. What can I do? Thanks
You simply need the cracked version, I have it on several of my computers and do not have a problem. Give me your email and I will help you with it. The system has no way of knowing if there are any other versions anymore with the website not working. Just ignore that. But you will need a new key and I can help you with that.
Here is the YouTube video from USCutter that shows installation & set-up of SignBlazer . The most recent info as of right now is in the video . The cracked version sounds good , but it is not needed . When the 6.24 version came out , the jamb ups I had with 6.21 stopped . I do not know the difference , just know it worked much better .
Benjamin ( Ninja ) narrates .
Can anyone give me a copy or a link to SignBlaster Elements. I need to reload as I have a new hardrive and can't find my CD anywhere. I have tried every one here with no results. I understand it will run in trial which is ok thats how mine ran. I have win 7
Check member Jay's last posts .. he just linked the Uk version with the patch .. works GREAT .. YEAH Jay :thumbsup:
Does anyone know what happened to the update version of this? It should be 6.0.24 Produced FEB. 25 2008.
I have it on my old laptop and like the way it works. It functions better for me than the 6.0.21 version that you can still download here. Any help would be great thanks
I also noticed when the 6.0.24 came out , things worked better & some issues went away . Since then I have reloaded from whatever has been available , most recently the UK version Jay linked & it is working great . Seems nobody has that link so search for the version you want , if you don't find it use the UK version . I don't have the cd that USCutter gave with the cutters , but I don't think that was 6.0.24 anyway . I think the update was thru Color Chrome First . The guy who made the patch for Sb said he did not see any difference , but I know the version you want did solve some problems for me . I did go to a serial cable after that though .
The downloads do not work with your links, please re-post.
Been having problems with my Refine MH-721 and Signcut Pro software. I grounded the heck out of the plotter and even upgraded the memory. The problem is the cutter seems to jump over sections it was suppose to cut. And it is very repeatable. Only happens on larger files (the file sent to the plotter was 503KB which isn't that large). So I wanted to try to cut using SignBlazer but there are several links that are old. Anyways, I finally found one that works:
http://support.uscutter.com/index.php?/Knowledgebase/Article/View/19/5/download-signblazer-software
I'm going to install per this YouTube video:
We will see.
Hi I downloaded the UK crack and followed the instructions and also used us cutter video to get it going .Now it cuts but cut some crazy box with x in middle I cant get it to cut correctly any suggestions from any one .Thanks
I have an MH350 cutter, and set it up with my old desktop computer. When I bought a new computer, I downloaded the SignBlazer from this website, but I forgot how to setup the USB driver so the software can "talk" to the cutter.
I still have the small CD-R for the USB Driver, but I lost the original sheet of instruction. Can anybody tell me where can I find the instruction on how to setup the USB driver so I can send send a cutting pattern from my computer to the cutter?
Thank you.
Iris
