captonzoom 2 Posted September 18, 2008 Is is best to use the text tool in SBE or from another program ( import text w/ image from another program)? Share this post Link to post Share on other sites
kenimes 42 Posted September 18, 2008 Whichever is easiest for you. Share this post Link to post Share on other sites
RegisG 0 Posted September 18, 2008 I always try to use the text in SBE (or whatever s/w you will actually cut from) if possible. Share this post Link to post Share on other sites
captonzoom 2 Posted September 18, 2008 Do you have any issues with small text. I am using a 60 degree blade for small text. Share this post Link to post Share on other sites
Jay2703 704 Posted September 18, 2008 The nice thing about using text from signblazer (if you use SB as your cutter program) is you can edit it later. If you import text is will come in as shapes instead of text. Share this post Link to post Share on other sites
mobby 1 Posted October 14, 2008 You should use text editor in SBE when ever possible. It is very limited compared with SB Pro, but does allow editing. A 60 degree blade is designed for reflective materials. I would use a 45 deg blade mobby http://www.computerandlaser.com.au/SB_Support.htm Share this post Link to post Share on other sites
Rodger 527 Posted October 15, 2008 Hi Mobby , You said you were going to shed some light on the status of SignBlazer ... have not caught any if you did Do you KNOW ; Is there a civil court case going on ? If so any court date ? I & many others would love to know there is hope that SB will get going again . Without Jerry , can't be as good , but if Bruce ( is Bruce the employee making the civil claim ? ) stays on board , mayby close to how it was with Jerry . Customer support for SignBlazer from Jerry & Bruce thru this board was as great as I've ever seen !!! regards , Rodger Share this post Link to post Share on other sites
