freebird1963 11 Posted June 4, 2007 When cutting the cuts go "down" the vinyl (the length side). How do I get it to cut along the width of the vinly ? Or should I cut down the length of the vinly ? Thanks Mark Share this post Link to post Share on other sites
ifingerpaint2 0 Posted June 4, 2007 I've recently posted the same question. I'm just learning, but what should work is to either rotate the image 90 deg. and it will lay it along the width. OR, go to the cut menu, and then prieview, there is an option to fit to width. My experience has been that this option stretches the image to fit the width, which messes up the image, but I'm assuming that somehow I am doing something wrong. I don't know if these suggestions will help you as I am still trying to find the answer myself, but these are what have been suggestied to me. Good luck! :- Share this post Link to post Share on other sites
