wilson83 0 Posted September 9, 2008 I've got this cutter almost 1.5 months ago, but never used contour. I decided to give it a try today, I followed the video guide on the other post, everything went well, the print comes out well, BUT ... - I can never get both of the registration mark to align to the laser. - If I align one of the laser to the middle (cross) of the registration mark (bottom right), I can't get it to align to the middle of the other (bottom left) registration mark. So I tested and tried to cut my sticker, the alignment was all out. I don't quite understand how this contour thing work. How do I align the laser? Am I supposed to have the laser pointing to the exact middle of the crossed circle? Or what? When it says jog to the registration mark, when I jog one step, it jumps either too much to the left or to the right, or too much up/down. Please help. Share this post Link to post Share on other sites
wilson83 0 Posted September 9, 2008 Hmm ... I figured out how to align the dots, pressed 5, then moved the direction ... okay now, my other question is, although I managed to center the laser to the middle of the registration mark/point, but the cutter still apparently cut a tad high, not where it is supposed to. Am I aligning it wrong? How should I align it? Or I need to do some other settings? Share this post Link to post Share on other sites
kenimes 42 Posted September 9, 2008 You got the jog step size figured out by pressing 5 on the keyboard- good. Not sure about the alignment....are you centering your print before you send it to the printer? Share this post Link to post Share on other sites
