jerseysignandgraphics 0 Posted May 30, 2007 every time i import a eps file to corel to add text or create somthing it will not work in signcut. i am curentely trying to make personalized sports decals and when i import the sport logo witch is a eps file it is fine in corell i can add text when i go to send it over to sign cut the graphic never shows up. just the text. i have had this with quite a few eps files from other sorces. how can i get the files to show up in signcut. i can upload one of the eps files to you through email if that would help Share this post Link to post Share on other sites
kenimes 42 Posted May 30, 2007 Might have something to do with grouping the graphic and text together in Corel. I ran into this problem in InkScape, and figured it out by grouping the text and the graphic, then saving again in .eps format, and then opening in SignCut. Share this post Link to post Share on other sites
Guest fivestar Posted May 31, 2007 I've never used sign cut but always convert your text to curves in corel and I'd group it together like Ken mentioned. Share this post Link to post Share on other sites
