edge 67 Posted May 29, 2007 When using Corel X3 I often get multiple cuts over the same cut line in SignCut with the Copam. I believed with bitmaps it was caused by varying degrees of brightness and contrast in different areas of the image when traced. But it also does it if I create a text only project in Corel. Is there a way to prevent this that I'm missing? Share this post Link to post Share on other sites
Guest fivestar Posted May 29, 2007 Always convert your text to curves. Share this post Link to post Share on other sites
Ric 0 Posted August 8, 2007 I had this same problem and resolved it by removing the fill from the objects. It appeared to me that the cutter was going around once for the fill and a second time for the outline. removing either resolved the problem. Share this post Link to post Share on other sites
