erick 0 Posted August 11, 2008 copam 2500 - plotter stopped in middle of a cut. All subsequent jobs sent to plotter result in blade moving to far edge of material and running non-stop to end of roll at methodical pace. Happens no matter how small job sent is. Solution appreciated. Share this post Link to post Share on other sites
Benr98 40 Posted August 11, 2008 First, are you trying to cut the same job just different sizes?? Share this post Link to post Share on other sites
erick 0 Posted August 11, 2008 Have tried sending various different jobs. Even tried typing a 1" letter and sending that. Same result. Share this post Link to post Share on other sites
Benr98 40 Posted August 11, 2008 One other thing, was it working fine before this, or has this problem been since you hooked it up?? Just trying to find out some details. Share this post Link to post Share on other sites
kenimes 42 Posted August 11, 2008 Which cable are you using to connect the cutter to your computer? Which program? Share this post Link to post Share on other sites
erick 0 Posted August 11, 2008 Plotter had been working fine. Purchased it in 2004. Share this post Link to post Share on other sites
erick 0 Posted August 11, 2008 Using winpc sign JSI-CUT program. LPT port Share this post Link to post Share on other sites
erick 0 Posted August 14, 2008 Have a feeling the problem is the plotter and may need another one. Share this post Link to post Share on other sites
kenimes 42 Posted August 15, 2008 Try a different connection method, could be the LPT cable going bad. Have you tried other software as well? Share this post Link to post Share on other sites
