Blues 18 Posted August 11, 2008 I have an artsign as720 plotter does anyone know if they make a driver that will let you use it with flexi? Share this post Link to post Share on other sites
kenimes 42 Posted August 11, 2008 Try the Roland PNC-1000 for Flexi. Share this post Link to post Share on other sites
Blues 18 Posted August 12, 2008 Tryed that one still won't work seems like it does the test cut fine but won't cut anything else. Share this post Link to post Share on other sites
kenimes 42 Posted August 13, 2008 If the test cut cuts fine.....then it should....hmmm. How about the RedSail 720 driver if it is availabel in Flexi? Share this post Link to post Share on other sites
Blues 18 Posted August 14, 2008 Tried that one to but no luck. What does the test cut look like when it does a test cut it cuts a square then a circle a cross then two lines but there all in the same spot. Then when you try to cut the blade just moves and then stops. Share this post Link to post Share on other sites
