ryan1633@hotmail.com 0 Posted February 26 Hello, Would anyone happen to know why the rotate button on the vinyl spooler is not working when I go to cut my contour cut? I created a contour print and cut using vinyl master. I printed the job which was 45" by 100". I had to print the job sideways because of course my printer isn't 100" wide. Now when I go to use the saved cut file for this contour cut it shows in the spooler as too wide. I have had this happen before and I hit the rotate button which would tell it to just feed the cut in the other way to fit. For some reason it will show as rotated correctly but when I click cut not and go to the arms lineup stage, it shows the width the wrong direction again. I swear I was able to rotate cut files before. Please see images for more context. Thank you. Quote Share this post Link to post Share on other sites
