Guest Swirlpop Posted January 15, 2023 I have the LTR version and I have been using it for the past 5 years now. I haven’t cut vinyl for about 3 years but I decided to get back into it. When I cut the first project everything is fine but when I cut the second project instead of cutting the design it cuts a huge squiggly line all through the vinyl. The only way to prevent this from happening is to turn off the machine or restart the program before cutting a second project. Is there anything to do so I can fix this problem Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 16, 2023 Using a MH cutter? I had this start happening when I upgraded from Windows 7 to Windows 11. I haven't tried restarting the program, I just turn the cutter on and off after every cut. Bit annoying, but probably not a bad idea to do with MHs anyway, they can go wonky pretty easily. Quote Share this post Link to post Share on other sites
