cswinkler 0 Posted March 31, 2022 My Titan has started cutting dashed lines in spots. It only happens on straight lines. Curved lines cut fine. I have called customer support and we have tried adjusting pressure, new blades, cut depth and the tension on the back of the machine on the feeder part. Still nothing has helped. Has anyone else experienced this and found a solution to it. THX! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 31, 2022 I answered your other post, but I will add, what does your teflon cutting strip look like? Check for scratches and gouges. Replace if needed. How did you set your blade depth? Too many see to use a credit card or post it notes, and that is just way too much blade exposed out of the blade holder. I gave you correct instructions on the other post. Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 31, 2022 Have you tried slowing down your cutting speed? Share this post Link to post Share on other sites
cswinkler 0 Posted March 31, 2022 Teflon looks in great shape. I usually set the blade depth with a credit card but I have even taken it out and tested it on vinyl by dragging it and adjusting until you can hardly see it on the backing. Share this post Link to post Share on other sites
cswinkler 0 Posted March 31, 2022 1 minute ago, darcshadow said: Have you tried slowing down your cutting speed? That I'm not sure. I know I have adjusted so many things but can't see for sure that I have tried that. I am going to try adding a drop of oil to the blade cartridge and then will slow the speed down to see if that helps. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 31, 2022 5 minutes ago, cswinkler said: Teflon looks in great shape. I usually set the blade depth with a credit card but I have even taken it out and tested it on vinyl by dragging it and adjusting until you can hardly see it on the backing. Credit card is about 20 times too much blade exposed out of the blade holder. I gave you correct instructions on the other post. You shouldn't even be able to see the blade tip out of the blade holder. Share this post Link to post Share on other sites
cswinkler 0 Posted March 31, 2022 Thanks for all the suggestions. So, far either oiling it or adjusting the cut speed may of worked. I ran three small test cust of lettering and those have cut good. Sure hope it stays this way when I cut my 24x48 piece today. Share this post Link to post Share on other sites
