DEvans422 0 Posted December 18, 2021 Machine will power on, fan runs, Reset light is on but no screen display and other control buttons do not work. Also VinylMaster cutter program no longer connects with cutter. Only used machine once with no problems. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 18, 2021 First, make sure the carriage head is not against the side reset button. If so move it away. (if it has a reset button) Make sure reset button is not stuck in. If it is a new cutter under warranty then contact UScutter, if that is where you bought it. We are volunteers here. UScutter rarely comes here. Share this post Link to post Share on other sites
slice&dice 2,450 Posted December 18, 2021 A machine that does not complete its self-test upon power-up is going to require major surgery. The automatic (power on) self-test means x, y and z axis movement (carriage slides, blade lifts and drops, grit rollers spin back and forth). Pressing the RESET button manually initiates this self-test also. Share this post Link to post Share on other sites
