Quadnickel 0 Posted October 31, 2021 I have a new issue after running the machine for quite some time. The head will not move (X-Axis or Y-Axis) and the Z-Axis is just chattering up and down quickly. The lights and display are flashing quickly. I replaced the Z-Axis chip and it did not fix the issue. Along with this, the fans are not running. I'm wondering if it is a motherboard issue or more and before I throw any more parts at it, I wanted your input. It is a MH13751 Model. Thanks in advance, Chris Jones Share this post Link to post Share on other sites
haumana 1,220 Posted October 31, 2021 Sounds like a 3-ring circus going on with your machine. Was the machine having all those issue prior to just replacing the z-axis chip? I would just save your pennies, and get a new machine, or if you can find one - a really gently used Graphtec CE6000 1 Share this post Link to post Share on other sites
darcshadow 1,627 Posted November 1, 2021 Kind of sounds like you need a new motherboard. Does the head move using the onboard control panel? 2 Share this post Link to post Share on other sites
