jz788 0 Posted September 26, 2021 New to the forum here. Have a family print shop that is mainly digital press printing. We have always sent our wide format and die cut stickers out for clients We are now looking into a wide format printer to do those things in house now. With the LP3, can you technically create die cut stickers and pop them out the sheet if you put the printed sheet on a cutting mat when you load it into the LP3 for contour cutting? I know a graphtec can do this but not quite ready to make a large investment in one. Any thoughts or advice for this newb would be appreciated Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 27, 2021 Technically no, vinyl cutters can not do die cut. Die cut involves large heavy equipment that stamps out the cut, kind of like a cookie cutter, the cookie cutter is the die. Can an LP3 contour cut printed decals? Yes. Can it perforate cut, sort of. In order to accomplish this you need to cut completely through the backing sheet of the vinyl, in order to do that on most vinyl cutters you need a cutting mat that the vinyl can stick to during the cutting procedure. This is how hobbyist cutters such at the Cricut work. The actual perforation cutting would be controlled by the software you are using. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 27, 2021 You may want to consider a used Graphtec FC8000 or 8600. They both can perf cut. Sometimes they can be found for under the price of a new Graphtec CE unit. I picked up a FC8000-75 a couple years back for $1,000 free ship. Took me less than 15 minutes to fix it. They had the cross cutter jammed on it. Share this post Link to post Share on other sites
