candidogarciajr 2 Posted March 11, 2021 We was trying to cut a circle graphic the first four are perfect but the last four when it comes to a full circle it does not connect it misaligned does anyone have that same problem or has a solution for it thank you Share this post Link to post Share on other sites
darcshadow 1,627 Posted March 11, 2021 Are they spread out across the width of the cutter? If so, could be a bad spot in your cutting strip. Share this post Link to post Share on other sites
candidogarciajr 2 Posted March 11, 2021 What do you mean the vinyl itself? Share this post Link to post Share on other sites
darcshadow 1,627 Posted March 11, 2021 Sort of. The four that are messing up, where is the cutter head in relation to it's location for the 4 that worked. Are they being cut in the same spot on the cutter or are they different? Can you post a photo? Share this post Link to post Share on other sites
candidogarciajr 2 Posted March 11, 2021 This is how it's cutting Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2021 Vinyl slipping, did you mess with the pressure rollers? also don’t make the plotter pull from the roll Share this post Link to post Share on other sites
candidogarciajr 2 Posted March 11, 2021 Ok I did mess with the pinchers cause I felt they were too tight and it was leave marks on the vinyl.wqs it wrong of me to mess with it? Also can you explain about the plotter pull? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2021 we see that all the time - the marks are totally normal and disappear when the vinyl is applied - by lowering the pressure you created your own problem with slippage always prefeed vinyl so the plotter doesn't pull from the roll directly - Share this post Link to post Share on other sites
candidogarciajr 2 Posted March 11, 2021 So basically leave enough material so that the cutter can pull freely and leaves the vinyl roll alone? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2021 yes - after you tighten the rollers again - if you can find where they pull even again Share this post Link to post Share on other sites
candidogarciajr 2 Posted March 11, 2021 Kool I tighten too cause I testing it and a 12x12 cheap vinyl I tighten to the point where the screw does not come out of the outer housing Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 12, 2021 19 minutes ago, candidogarciajr said: Kool I tighten too cause I testing it and a 12x12 cheap vinyl I tighten to the point where the screw does not come out of the outer housing Yup way way too lose Share this post Link to post Share on other sites
candidogarciajr 2 Posted March 12, 2021 Sorry was busting my head over this but I think I got it is this better Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 12, 2021 Good to hear Share this post Link to post Share on other sites
candidogarciajr 2 Posted March 12, 2021 Thank you so much for help have a good night 2 Share this post Link to post Share on other sites
