Tom Godon 0 Posted January 3, 2021 I have design that I am cutting in 3 colors for different parts of the same decal. The first two colors have cut fine, those are vector images. The 3rd color I am cutting is text I entered within SignBlazer. I have tried it two times and both times it cut two diagonal lines across that are not a part of the overall image. Anyone know how to fix this? I have attached the SignBlazer SBD file. The issue is with cutting what is shown in yellow on the image. Aprilia SXV Supermoto.SBD Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 3, 2021 Export as .eps. Most software can import .eps files. Many people on here don't use Signblazer. Most have newer software on here. We cannot import it. Share this post Link to post Share on other sites
Tom Godon 0 Posted January 3, 2021 Part of the whole file was an EPS I imported, then added registration squares and text from within SB. The imported EPS parts and registration squares cut correctly. When I cut the text I typed within SB and the registration marks I am getting the 2 diagonal cuts which partially go through the letters. Hope this further clarifies the issue I am having. I am going to try removing the imported EPS parts and see if the issue goes away. I have cut both imported EPS and text I have entered with SB, just not part of the whole project as one file. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 3, 2021 Nope don't help. Share this post Link to post Share on other sites
Tom Godon 0 Posted January 3, 2021 Hmmm. I watched it cut. The diagonals it is cutting seem to have something to do with the weeding boxes it is cutting. I think I know what I need to do to resolve it. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 3, 2021 FILE>EXPORT, chose .eps at the bottom. Share this post Link to post Share on other sites
haumana 1,220 Posted January 3, 2021 If you think it's the weed box, then turn off the weed box and make your own. I don't ever use the weed box option. I draw in all my own weed cuts. 2 Share this post Link to post Share on other sites
