Guest gracewriter
Why can't I weld these?
Guest gracewriter
I have several signshape graphis that when I try to weld including the fonts, as soon as I weld the fonts disappear.  I"m getting really tired of combining them, makes weeding the fonts tedious because of those little extras it leaves behind.
Can someone help with this?
I'll post one of the files.
weld.EPS
weld.EPS
Guest Terry
Not sure if I understand, but if you weld them the fonts would disappear, because you make it a part of the sign.
Guest gracewriter
I don't have this problem with some of the sign shapes.  It's really weird.  On some I weld and they come out perfect.  Others like this one the fonts disappear.
Guest Terry
I think some work because it is K/O of sign, not a color text, two colors. It is just a single color sign K/O.
Guest Terry
The borders on sign are not there, they are a cutout, the text and crown you added are a second layer to put on. Or send all colors at once and it would cut the text out as it does the border.
Try a Combine instead of weld. It will cut the text out of the background.
Guest gracewriter
Thanks Jay.  I've been using combine, just tired of weeding the fonts.
Terry, I can't open the eps.  can you send it jpeg?
Guest gracewriter
Why is signblazer so finicky and not let me just open an eps file from my desk top?!  Never mind.  I remember there's a trick to getting it to open but can't remember the trick at the moment.
Try to weld just the font first, then do a combine.
Guest gracewriter
I think I tried that already, but I'll do it again.
Guest gracewriter
Tried it, didn't work.  Thanks anyway.
Guest gracewriter
Huh?
Guest Terry
If it won't open in blazer... open in Illustrator and resave.
Guest gracewriter
I can't get this file to open in signblazer.  Do you know how I can open it?  This is very frustrating.
Guest gracewriter
got it to open in illustrator. How do I get it into signblazer?
Guest gracewriter
Can't unzip--wish I'd said that before the last baby.
or wish HE had said it?
